Wood vs Pellet heat ???
   / Wood vs Pellet heat ??? #71
I thought the thread title read "Wood vs, Pallet Heat"
Thanks TBN :D
When burning “ pallets “ watch out for the nails and staples.
Re: “ pellets “ yes and now it has branched out into exercise and methods of obtaining wood vs pellet heat and all things associated :D
   / Wood vs Pellet heat ??? #72
I was talking with the neighbor the other evening while we both out moving snow. He put in a pellet stove about ten years ago after suffering a chimney fire with his wood stove (he has had a history of misadventure that way)
With insurance money to have the replacement pellet stove installed properly, he got a high end (quad fire?) and a lined chimney.
He likes the pellets well enough, and though he gets the dealer (reputable) to service the system every spring, he can't seem to keep ignitors in the thing. He is on his second one this season already. Plus the auto ignition is spotty at best.
He is at the point of cleaning the combustion basket every evening after coming home from work. The stove is shut down and allowed to cool, then it's a bristle brush and a hooked pick to get all the holes in the basket cleared out.
The ignitors are not costly, $30 IIRC, but installation is laborsome by his account.
The entire conversation has turned me against putting in a pellet burner to replace the 40 year old Fisher log wood stove that has served without fault. (Other than burning lots of wood! ;-)
   / Wood vs Pellet heat ??? #73
I spent many years with a Fisher Mama Bear, the house is still in the family and the old stove is still going strong. Good stoves, will last forever.
   / Wood vs Pellet heat ??? #74
Which ever stove you decide on. My recommendation is for it to have an ash pan. Makes cleaning simpler and faster all around.
Or fire place insert does not have an ash pan. But in our case beggars can't be choosers since we had the stove given to us. I have to clean out the ash every couple of days. If it had a pan, it's just a matter of pulling it and dumping it out.
   / Wood vs Pellet heat ??? #75
Wood really splits easily when it is cold out!
My spitting maul disagrees with you. It was complaining big time last Thursday.
   / Wood vs Pellet heat ??? #77
   / Wood vs Pellet heat ??? #78
I kinda doubt that, but it wouldn’t be hard to weld on another handle.
That's what I will have done but it was disappointing. I was working on some hard elm that I tried to split when I cut the standing dead tree last spring but it just went thud. So I waited until we had some good cold weather for easier splitting. Most of it was split when this happened while I was doing the largest round. Out came the saw.
   / Wood vs Pellet heat ??? #79
   / Wood vs Pellet heat ??? #80
I had a Mama for ~30 years at my previous house. Wife thought it was ugly, so when we moved here we bought something else. Decent quality stove, though kind of a PITA to clean out since there's no ash pan. Still have it, it's in my workshop. Can be a little finicky until you get a good draft going, then it's OK.
SOME Harman stoves are easy to clean (I've been told). Others are a bear. I have heard of one person that replaced his Harman Advance with a different model Harman just because of the difficult cleaning.
My current woodstove is a Harman Oakwood. Very nice. Only complaint is that the ash pan is a bit shallow, and tends to warp slightly when hot making it difficult to remove.
Once you learn the tricks it isn't too hard to clean. There's a secondary combustion chamber on the back that some of the soot is cleaned from the top, the rest from inside the stove. Found that if you remove a couple firebricks it's pretty easy to get at what can be reached from the inside. Generally need to replace all the gaskets every couple years...the damper door gaskets are a bit of a PITA to get at.
As far as pellets vs wood, seems to be a matter of personal preference. To me pellets would be OK in a workshop or if the stove isn't in living space since the blowers are kind of noisy. Another concern of mine would be pricing/availabilty of pellets. Sure prices are fairly stable now, and availability is good, but as with any other produced product shortages and/or price spikes are possible. Firewood is easy to come by here. If I was a suburbanite I might think otherwise.
The fact that a pellet stove needs AC power to operate makes it less desirable in my book in that it's just a paperweight if there's a power outage.
LOOK! (A53342)
LOOK! (A53342)
24ft Gooseneck Trailer (A51572)
24ft Gooseneck...
2020 DEERE 318G SKIDSTEER (A51246)
2020 DEERE 318G...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2009 John Deere 1810E Scraper Pan (A53342)
2009 John Deere...
