Wood to steel cutting bandsaw
   / Wood to steel cutting bandsaw #1
ericher69
Ontario Canada
2008 Kubota b2920
I I have an old wood cutting bandsaw that I would like to convert to cutting steel. Pictures to follow
One problem; it turns way too fast!
Here are the measurements
Drive motor 1745rpm
Drive pulley 1.5"
Driven 7"
Band wheel diameter 19"
Band length 124"
I found an app for my phone and a few online calculators to figure fpm rate and come up with 900fpm
What would be the easiest way to slow this down to less than 200fpm (cheapest way)
Thanks
   / Wood to steel cutting bandsaw #2
you need a triple pully witch are hard to find or mady a bigger one. also you would need to buy some bimetal blades to cut steel.
Triple pulley on motor to be able to change speeds easily?
I need a fpm rate of 80-200 fpm
Got a brand new Lenox die master 6/10 tooth pitch blade.
   / Wood to steel cutting bandsaw #4
I have a band saw that is made for wood or steel. It has a small gear box that tremendously slows the blade down (for steel) as well as having a 3 position belt. Is a small garden tractor transmission possible?
   / Wood to steel cutting bandsaw #5
You might want to search the archives at OWWM.org somebody is bound to have asked that same question over there, and they have a lot of experts on older wood and metal-working machinery.
   / Wood to steel cutting bandsaw #6
Delta made a multi speed 14" wood and metal saw. I recently bought a very nice one for $300. I also have a $100 job I bought at a machine shop auction that has the motor replaced with a 2 sheave pulley and the motor now mounted hanging off the base driving the fist pulley making a reduction if you follow me. Very Mickey Mouse but works fine. Owwm is a good idea too.
   / Wood to steel cutting bandsaw #7
I have read about guys using a variable speed motor from a tread mill (heavy duty and cheap). The blades you will need could be custom made but might be expensive.
   / Wood to steel cutting bandsaw #8
You'll could do like drill presses do and use an idler in the middle to get the step down you need. In trying out a calculator you would need a 1" drive pulley and a 36" driven pulley to get even close, so you will probably need to step it twice. You could maybe steal the pulley set from an old drill press and find a speed setting that works. Looks like you want to get the driven wheeldown under 50 rpm, so maybe a 35:1 gear box would do that for you. Try Surplus Center, perhaps
   / Wood to steel cutting bandsaw #9
If you have a brush type motor on it, this should work and is a simple fix.
I have read in other forums where guys not only use this on routers, but on other things as well.
Router Speed Control
   / Wood to steel cutting bandsaw #10
BS motors are generally induction motors as they are anywhere from 1/2 hp and up. Depending on how small this BS is, perhaps it is a brush-type motor, but that is not the type I see on anything I think of as a bandsaw.
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A53472)
2023 Maxx-D TDX...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
