Wood to steel cutting bandsaw
   / Wood to steel cutting bandsaw #1
ericher69
Ontario Canada
2008 Kubota b2920
I I have an old wood cutting bandsaw that I would like to convert to cutting steel. Pictures to follow
One problem; it turns way too fast!
Here are the measurements
Drive motor 1745rpm
Drive pulley 1.5"
Driven 7"
Band wheel diameter 19"
Band length 124"
I found an app for my phone and a few online calculators to figure fpm rate and come up with 900fpm
What would be the easiest way to slow this down to less than 200fpm (cheapest way)
Thanks
   / Wood to steel cutting bandsaw #2
you need a triple pully witch are hard to find or mady a bigger one. also you would need to buy some bimetal blades to cut steel.
Triple pulley on motor to be able to change speeds easily?
I need a fpm rate of 80-200 fpm
Got a brand new Lenox die master 6/10 tooth pitch blade.
   / Wood to steel cutting bandsaw #4
I have a band saw that is made for wood or steel. It has a small gear box that tremendously slows the blade down (for steel) as well as having a 3 position belt. Is a small garden tractor transmission possible?
   / Wood to steel cutting bandsaw #5
You might want to search the archives at OWWM.org somebody is bound to have asked that same question over there, and they have a lot of experts on older wood and metal-working machinery.
   / Wood to steel cutting bandsaw #6
Delta made a multi speed 14" wood and metal saw. I recently bought a very nice one for $300. I also have a $100 job I bought at a machine shop auction that has the motor replaced with a 2 sheave pulley and the motor now mounted hanging off the base driving the fist pulley making a reduction if you follow me. Very Mickey Mouse but works fine. Owwm is a good idea too.
   / Wood to steel cutting bandsaw #7
I have read about guys using a variable speed motor from a tread mill (heavy duty and cheap). The blades you will need could be custom made but might be expensive.
   / Wood to steel cutting bandsaw #8
You'll could do like drill presses do and use an idler in the middle to get the step down you need. In trying out a calculator you would need a 1" drive pulley and a 36" driven pulley to get even close, so you will probably need to step it twice. You could maybe steal the pulley set from an old drill press and find a speed setting that works. Looks like you want to get the driven wheeldown under 50 rpm, so maybe a 35:1 gear box would do that for you. Try Surplus Center, perhaps
   / Wood to steel cutting bandsaw #9
If you have a brush type motor on it, this should work and is a simple fix.
I have read in other forums where guys not only use this on routers, but on other things as well.
Router Speed Control
   / Wood to steel cutting bandsaw #10
BS motors are generally induction motors as they are anywhere from 1/2 hp and up. Depending on how small this BS is, perhaps it is a brush-type motor, but that is not the type I see on anything I think of as a bandsaw.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
