Wood stove top fans (heat powered)
   / Wood stove top fans (heat powered) #81
But radiant energy travels in WAVES, Riding on the ether! ;-)
Oh! Planck and all his bothersome quanta!!
Really, travelling in waves on the mystical ether? ?
The point was radiant energy does travel from the point sources it was emitted from. The emissions may be of variable intensity and frequency.
Just simple bottom pay grade observations.
   / Wood stove top fans (heat powered) #84
You keep saying that but always fail to explain it.
The floor is yours...
Radiant heat transfer - via electromagnetic waves, like light or tv radio cell phone signals
convective heat transfer - via gas molecules, like air
conductive heat transfer - via solid contact, like the fan base setting on the stove top
stove heats the surrounding air by convection. those ads u see about convection ovens are misleading. No fan is needed for convection. Moving air speeds up the transfer, but convective transfer happens in air weather external movement is used or not.
   / Wood stove top fans (heat powered) #85
Radiant heat is infrared waves, not electromagnetic.
I was expecting more from you than this, especially since you made such a big stink that you knew it all.
   / Wood stove top fans (heat powered) #86
Critical Thinking Class in the 5th grade. (evidently not taught anymore).
We did a experiment to see how heat effected molecular movement. Four glass beakers, one with water at 39 degrees F. One with water at room temperature (was measured to be 68 degrees F.) One beaker with 130 degree water and one with water at approximately the boiling point.
A drop of red dye was placed in each beaker to watch what happened to the dye at different temperatures.
Our question to answer was, which beaker had the most mixing of the one drop of red dye and what caused the mixing of the dye?
   / Wood stove top fans (heat powered) #87
were you shocked to see boiling water mixed the dye better?
   / Wood stove top fans (heat powered) #88
Look up the definition of infrared waves...
Infrared waves are electromagnetic radiation of a particular wavelength or color that we have named 'infrared. ' They are between 700 nm (nanometers) and 1 mm. ...
Geeze.
   / Wood stove top fans (heat powered) #89
Geeze.
electromagnetic is a broad term of all wave lengths and infrared is a specific to the radiant heat spectrum
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
706075 LOT IDENTIFIER 77 (A53084)
706075 LOT...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
PALLET OF VIGORO HD FABRIC & GARDEN STAPLES (A51248)
PALLET OF VIGORO...
