Wood Splitter advice
/ Wood Splitter advice #21
I'd be more interested in the Super Split if it came with a log lift, and if the wedge was on the movable portion and the log stayed in place. It just seems like you have to lift every single round quite a bit high in the air up to the splitter, and then handle every single piece of wood again if you want to re-split. I think this would be fine for most people but I like to split my wood fairly small, so I re-split almost all the time. Also, how on earth do they NOT offer a 4 way option? Then I might be persuaded, but for now, I honestly just can't see how you can beat a Split-Fire splitter. But then again, they're what....double the cost??? I'm sure that's the reason you don't see a lot of them.
/ Wood Splitter advice #22
I burn about 2 cords a year, and my parents burn another 2 chords. I learned a long time ago that if you are going to have a small engine, it has to be a Honda. Nothing else matters, get something with an engine that starts easily every time, year after year. My splitter is a Troybuilt that I bought from Lowes with the Honda engine. I think that most of them in the same price range are close enough to not matter except for the engine.
/ Wood Splitter advice #23
I agree! And get the GX series!
/ Wood Splitter advice #24
I have the same splitter with the Honda. I have had several mowers with Hondas - always start 'first pull'. Nodt that splitter. Takes at least two pulls and the rewind spring does not have enough tension. On a warm day it will rewind, on cool or cold days I have to use a screwdriver to rewind it. I should take the starer apart and add another wrap but my experience has usually wound up with the coil spring all over the shop.
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
