wood protectant
/ wood protectant #1
poorboy
Eastern Kentucky
Getting ready to refloor a bridge that would connect our farm to another piece of property my dad just bought. Anyway, going to refloor with whiteoak 3x6s because of expense and availability. My question is I would like to know what I can apply to the floor to slow down decomposition of the wood. It's about 125'ft long and 14' wide.
/ wood protectant #2
I have used Creosote or carbolin oil to treat wood in the past. You can paint them on. Both seem to work okay but I never drove on them wet after I did it. They are both some kind of oil derivative so I suspect they would get pretty slick. Maybe somebody else knows something better. Most of the wood deck coatings don't last very well.
/ wood protectant #3
I use foundation sealer and driveway sealer, works excellent, you may have to reaply where you drive.
/ wood protectant #4
I'm going to suggest something that probably will raise a storm of protest, but it has worked for me. I have a 16 foot flatbed trailer with a plank bed that sits outside. The planks started to deteriorate and I tried several commercial preservatives and they didn't seem to do anything at all. Sure, at first they looked good, but after a few weeks it didn't seem like there was anything there at all. Following the advice of a local welder (a friend and man of great genius) I mixed waste oil (10-30 W) with a bit of diesel fuel and applied two coats. I did this over a year ago and this coating has held up just fine. I sure wouldn't do this when planks were in place on the bridge and risk spilling oil into the water. Also, my trailer planks were rough so they didn't become slick; I suspect that smooth finished planks might be slippery. By the way, I've been "chewed out" by an acquaintance who says that motor oil is too toxic to mess with. I guess you'll have to make up your own mind about this.
/ wood protectant #5
In my opinion, the best solution is to use pressure treated lumber. If you can't buy treated lumber in the size you need, I've taken my own lumber to a treating facility and they've pressure treated it for me for a reasonable price. This particular place was in Maryland but I suspect there are "treaters" in every state.
Larry...
/ wood protectant #6
Glenn,
I agree with I do the same thing. My grandpa used to always fills 55 gallon drums with used oil and leave posts in it that we were going to use for fences for a couple weeks. There are posts that are 30 and 40 years old that we've pulled that show no signs of rot at all and still had the oil on them. The wood is going to be dryer than the soil so I can't see that too much of the oil would go into the soil anyway.
/ wood protectant #7
My brother-in-law uses diesel fuel to treat lumber for waterproofing and it works well. He just paints it on but if you have 125' by 14' you may want to put in in a pump sprayer and spray it on before you install the planks. Just try not to get the diesel in the water. There may be a little diesel smell when you cross the bridge but you should not mind that.
/ wood protectant #8
You've got a pretty sizable bridge to treat, so I'd say spray it with something oil-based (e.g waste oil). For something so large, the cost of a commercial preservative like Thompsons would be pretty darned $$$. Try a paving contractor that has one of those hot-tar-oil spraying rigs... that might be cost effective too.
/ wood protectant #9
I too have a bridge that needs re-decking. I am told that Creosote is no longer legal to use here in Maine. Also, our Dept. of Environmental Protection takes a dim view of any oil based material around a stream or brook--including pressure treated lumber. Anyone know of any organic wood perservatives?
/ wood protectant #10
I agree with the oil treatment. People around here use it on sheds, barns and even some log camps. I would thinks by using comman sense, one would not get little if any on the ground or in the water.
Derek
/ wood protectant #12
Re:0il treatment
around here the folks use crude oil for the treatment of sheds, wood posts etc... i have not needed it myself, but seems to work very well, a lot cheaper than anything else you find, would not spray this near a stream, would treat the wood and let it dry before i put it on the bridge deck. they seem to need to retreat about every 3 years so they tell me.
/ wood protectant #13
Something else came to mind about using waste oil for treating lumber. Some of the old wooden fishing boats on the Great Lakes (the ones with the diesels that go "chunk-a-chunk-a-chunk" when they venture out at daylight) had their bilges soaked with waste oil to ****** rot. It must have worked because some of them are decades old and still functioning. However, imagine, if you can, what one of these smells like after being soaked in oil and then carrying fish for half a century!
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
CID FDM60-S 60in. Hydraulic Forestry Disk Mulcher Skid Steer Attachment (A66734)
CID FDM60-S 60in...
2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
