Wood light post
   / Wood light post #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I want to add some lighting in a few spots around my property. Nothing too bright, just down lighting. 1 near a gate to the barn and 1 or 2 next to the driveway bridge over the creek. I want to use a 6x6 post rather than a telephone pole and can get them up to 16 feet long.
This is the light (I would get black, not red):
How high would you put the light? How likely is it that the 6x6 will twist over time? Any other advice?
   / Wood light post #2
At least 10 ft high, and consider LED's or fluorescent lamps so you save on your electric, and won't have to climb up there as often. LED's can easily use 1/10th the power of incandescents.
   / Wood light post
I'm all for LEDs.
   / Wood light post #6
higher the better. if you want down light only.
myself prefer
http://www.menards.com/main/outdoor...p-2428373-c-7544.htm?tid=-7634301683433198115
the ability to angle 2 lights in different directions. does a better job for me. and being able to give some better direction light per say. via flood lights put in them.
a down light, just never focus enough light were i need it. and if it does focus light were i need it. i end up swarmed with bugs, and picking bugs out of my noise, and coughing a few up, and doing the bug dance, due to some going down shirt or up shorts... due to light source to near me.
might suggest getting 1" to 2" metal pipe vs 6x6. so you can extend lighting up higher. flag poles that bend down might be another option. so you can replace bulbs and like. if you want a "wood look" you could always buy say 1/2" paneling that has a wood finish to it. and then build a box around the metal pole, kinda like a fake beam, i have a couple in cabin, and my mom house has a few fake beams in the ceiling down stairs. just for the purpose of running electrical / water / sewage / etc..
   / Wood light post #7
First off, how deep can you dig the hole? I can dig 3 feet with my auger. I use a 12 inch auger and it takes several sacks of concrete to fill it back up. While backfiling with dirt is ok for a fence, it's not good for a light pole because it's being pushed and pulled by gravity and the weather in all directions.
A 16 foot treated 6x6 is a heavy chunk of wood. I've installed them by myself, but I was at my physical max walking them up into the hole. If you are really strong, then that wont be a problem. With lights, I've found that the higher up you go, the happier you will be with the results. All of my street lights are 13 feet tall, which is why I would recomend going with the 16 foot 6x6's.
As for twisting, it's a guess which posts will and which ones wont. No way to tell by looking at them. Pick out the straightest, driest ones in the stack and you might get lucky. Personally, I've had much better success with round poles staying straight once installed. For my own lights, I went with 4 inch galvanized pipe. Cost is about a hundred bucks each and you have to use the tractor to stand them up, but once set, they are there forever and they will never twist or bow on you. Mine are painted black, but you don't have to paint them, just leave them the natural silver color of the galvanizing finish.
It's just as easy to use self tapping screws to attach the light to a metal pipe as it is to screw into wood. Almost :)
You can hide the wiring inside the pipe and then drill a hole in the side to run the wire out to the trench. That makes in nice and clean and you never have to worry about anything hitting the wiring
   / Wood light post #8
Just today I was thinking about light poles for my 1000 foot driveway. I had thought about 6x6 poles and the possibility of them warping. I had thought about screwing a piece of angle iron to each one for a couple years. Figuring that would keep them straight as they dried out.
   / Wood light post #9
Here is what I built for my driveway
   / Wood light post #10
Thanks Eddie, I wanted out of New York bad enough before I saw your Pics. .....:(
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
Toro Mower (A50324)
Toro Mower (A50324)
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
