wood butcher
/ wood butcher #1
mjc
Hillsdale N.y.
john deere 990 tlb
990 shim kit
I have a J.D. 990 tlb , I was wondering if anyone has installed a hydraulic shim kit
in a 990, I know that they make the shim kit for the 790 , but I can not find any listing for a shim kit for the 990 at the dealer. Or if any ideas how I could increase hydraulic pressure by 10 to 20%. Also has anyone had trouble with a
8b hoe sagging while in use ,( dipper stick and outriggers falling slightly while in use)? Many Thanks
/ wood butcher #2
Welcome to TBN:D
BEFORE you worry about raising the pressure-get a gauge setup and find out what yours is set for now. I am not sure if the 990 uses shims or just a screw and jamb nut to set the PRV.
Cylinders leaking down is usually a sign that need rebuilding. Seal kits vary in price from $25 to $100 at the dealer or you can find a local shop to get the rebuilt.
Hopefully you will get some other views, your post title is a little strange:confused:
/ wood butcher
Thanks for the help Kennyd, Sorry about the post title , I will check the hydraulic pressure 1st, I believe it should be fairly close to the factory spec's,
I don't see any jamb nut to adjust the hydraulic pressure , thats way I am guessing it is like the 790 and uses a shim kit.
I did talk to the dealer about the back hoe , and their suggestion was to
install a back flow valve, Their thought was that it would be unlikely to be the seals because all the cylinders drop at the same rate , they don't drop that quickly but over an hour they drop 3-4 inches or so , this has done this since it was new.
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
2009 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2009 INTERNATIONAL...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2018 DODGE RAM 2500 (A67714)
2018 DODGE RAM...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
PORTA POTTY (A67714)
