wont stop dying!
/ wont stop dying! #1
Bwgad96
Huntingtown,MD
Wayy to many.
I have an old craftsman lawn mower with a 15.5 hp briggs and stratton on it. it will run fine for about 2-3 minites then start to make some nasty coughing noises and it will do this for about a minute or so be fore it finally does out. ive cleaned the carb, and completly tore it down and soaked it overnight then rinsed out with water and let dry for about an hour in direct sunlight. u am thinking it is the coil gettin hot, because after it dies out it wont start till it cools down. any ideas/comments? thanks
/ wont stop dying! #2
I have a Poulan with a 15.5 that acts similar, crank it up and it runs fine for about 10 min. and then starts smothering down and cutting out. It has never died on me but today I had a hard time starting it, it would backfire and run a little and then finally started but ran rough. I cleaned the carb. last summer(Nikki) with no good results. I suspect the coil may be overheating but have not priced a new one. I'm sure they're not cheap. I removed the engine cowling and cleaned out all the dead grass, a mouse nest, mouse skull(wonder what killed him?:laughing:). I also checked the intake manifold gasket at the block for damage. I had one mower that acted like this one and the intake manifold gasket had torn. Does yours have the solenoid on the bottom of the carburetor bowl? I am suspecting that may be the problem with mine. I have done the valve adjustment several times and it has made no difference. Have you removed the gas cap when it is running rough to see if it is venting ?
/ wont stop dying!
yes sir I have done quite a few of these things.ive tried the gas cap with no luck, and mine also does have the sylinoid at the bottom of the carb( walbro) which is functioning properly so when i turn the key it pops open. I looked ot up and a new coil is about 35.00 bucks. I think im going to go to my neighbors house who has about 5 of these and buy one off a parts machine.
/ wont stop dying!
I am really staring to think my problem is that silly sylinoid closing up on me!!
/ wont stop dying! #5
I have read of some people replacing the solenoid with a brass plug and gasket. I don't know if you have to ground the wire to the solenoid or leave it open. I would like to try that on mine but I have too many irons in the fire right now. I prefer a Walbro over the Nikki carburetor.
/ wont stop dying!
Thats a great idea where could i get one of those brass plugs?
/ wont stop dying! #7
Just remove the solenoid, clip the plunger and reinstall. You may have to experiment shutting the engine off at different throttle settings to prevent it from backfiring.
Jim
/ wont stop dying!
Ok, so that issue is fixed!! But sadly it is still doing this sputtering. So im pretty sure my issue now is the coil.that is my best guess any input?
/ wont stop dying!
im still up in the air about ordering the coil, any other imput?
/ wont stop dying!
New coil came today, an theres no diffrence. Runs beutiful for 10 minites tuen sputters and dies. im stumped!!
/ wont stop dying! #11
My tractor does the same thing what did u do to get it running
/ wont stop dying!
See its funny mine rane fine then started having the issue.i know my carbs clean and there is no trash in my gas or line. I have replaced the coil with no change. Just because im going to change the fuel out.
/ wont stop dying!
Changed out fuel today, no change...
/ wont stop dying! #14
I know you have checked and cleaned the carb but now you need to narrow down which one of the three critical items you are missing. Compression, ignition/spark or fuel.
When the engine gets hot and stalls check for spark. No spark the problem is electrical. Could be a bad plug. Check using a cold plug. Possibly non-resistor Vs resistor type also.
If you have good spark check the compression. Possible a valve needs to be adjusted causing loss of compression, but I would think you would hear this.
Check for fuel flow to the carb. Is this a gravity flow system or fuel pump system? On fuel pump systems, check the hose to the pump for weather checks or cracks. These can allow air to be sucked through the hose Vs gas from the tank.
Other possibility would be the timing shifting but this should show a weak spark.
Roy
SHOP PRESS (A64278)
SHOP PRESS (A64278)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
New/Unused Fuel Delivery Tank with Pump (A65583)
New/Unused Fuel...
John Deere 980 28' Field Cultivator (A66285)
John Deere 980 28'...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
