wont start
/ wont start #1
EddieDial
I stalled my L 3430 while bush hogging, now it won't start any ideas?
/ wont start
No, I disengaged the PTO, and it cranks, and it does sound like its out of fuel, but I dropped the fuel filter, and even cracked the lines to the injectors to make sure, it seems to be getting fuel.
/ wont start #5
Can you hear fuel control solenoid engaging when ign switch is turned to "on"?
/ wont start
Jim, I pulled the return fuel hose and It seemed to have plenty of pressure so today I am going to bleed the injector lines (again) just to make sure its not a fuel issue, whats next if I'm getting fuel,and thanks to you and Wolfy for the help, I work so I may not always be able to get on the forum right away.
/ wont start #7
May not be related at all but 2 different things have happened while running Kubota 9540 in rough conditions. 1- Something snagged the fuel lines under the tractor and pulled them loose from the fuel tank. 2- Something somewhere on the right side of the tractor is a small triangle shaped thing if I remember correctly. It can be in one of 2 positions. One position and it won't run. Buddy fixed it so I really didn't see it. Not sure if it's a fuel cut-off or what
