wont start with out starting fluid
   / wont start with out starting fluid #1
gcocozza
53aa5b6l710 cub cadet
I have a zero turn z-rider cub cadet with a kohler 20 HP CV20s. The motor wont start unless you spray starting fluid into the air breather. it runs great after it starts. Shut it off and you have to do the above again to get it started.
   / wont start with out starting fluid #2
Can you perform a compression test? If yes what is the compression on each cylinder?
After cranking the engine, pull the spark plugs to see if they are getting wet.
Does it smoke when it starts?
Hold the plugs against the head and crank it over. What color is the spark?
Answer these questions and some one can probably help point you in the direction of a cure.
Roy
Roy
I will check the above things. I can tell you after you spray it, it smokes when it starts. I will check the above and get back to you. Thanks
   / wont start with out starting fluid #4
also visually check to see that choke butterfly plate in carb throat is fully closing when choking for a cold start.
   / wont start with out starting fluid #5
Starter fluid can cause a strain on the engine, hense the smoke. maybe seafoam can help you get enough gas to make it crank normally?I agree on the choke, that makes a big difference on a cold start..
   / wont start with out starting fluid #6
The engine runs great after start up because it is now running on the main jet. I think you have a low speed jet problem. There may be a damage seat in the low speed jet.
Check choke setting.
Here is the service manual for your engine.
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2450_c.pdf
Clean out solenoid control in the bottom of the carb if it has one.
Set the low speed jet 2 and 1/4 turns out from bottom.
Check fuel pump supply.
To much of that starter fluid will pop a hole in the piston.
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55315)
2012 Ford F-150...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2018 Infiniti QX60 AWD SUV (A55853)
2018 Infiniti QX60...
