Wolfsnout Trimming / Mowing Dust Mask
   / Wolfsnout Trimming / Mowing Dust Mask
Wolfsnout® OFF ROAD #1 MOTOCROSS/ATV/UTV DUST MASK/FILTER/OFFROAD
Wolfsnout® Lawn Mowing/Cutting Dust Mask
The Wolfsnoutï mask fits under your nose and over your mouth. So your nose and mouth are not confined in the same compartment. This unique design combined with our depth
loading filter foam, allows for a super easy breathing feeling. It does not trap hot C02 like the paper throwaways. Your exhaled air whisks easily away. Perfect for breathing at a
fast paced breath. Spring through Fall, the light weight design can be beat in the Summer heat. The super soft face seal, and nose filter provide comfort for all day use. It will not
clog when wet from sweat, like paper masks. Also, since it fits under your nose, it never vents under your goggles or glasses, fogging them up. Clean up is a snap, simply wash it
out with mild soap and cold water, squeeze excess water out, and let it dry over night. Mask can be used wet. If taken care of, the Wolfsnout mask can last several years
(depending on use) saving you money, with comfort that cannot be beat.
The Wolfsnout mask was invented and is produced in the USA. It was originally designed for ATV, UTV, Mx and other offroad sports where breathe ability was a must. As
the off-road community embraced this product it quickly became apparent that it was the perfect landscaping dust mask.
The Wolfsnout® mask can't be beet in the summer heat!
Re: Wolfsnout landscaping / Mowing Dust Mask
A couple of guys using the landscaping dust mask by Wolfsnoutï½®. They say they use them mowing trimming and blowing most every day.
These guys are professional landscapers.
2014 CASE 586H FORKLIFT (A52576)
2014 CASE 586H...
JLG MAN LIFT (A52472)
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
