Wolfsnout Trimming / Mowing Dust Mask
/ Wolfsnout Trimming / Mowing Dust Mask #1
Wolfsnout
Advertiser
Lilburn GA
vendor
WOLFSNOUT MOWING, TRIMMING, BLOWING MASK
Washable and Reusable. With a super Soft Moisture Wicking Face Seal
Are you sick of breathing grass and dirt while you work?
Can't stand the paper masks that get wet, clog and fog your glasses?
One Wolfsnout mask can replace hundreds of the throwaways
we all hate so much and offers great comfort from spring through fall.
Finally everything you would not expect from a dust mask.
The patented under nose filter foam system separates your nose and
mouth for a superior free breathing feeling.
The Wolfsnout dust mask was originally designed for and is #1 for
off road riding. The requirements for these rigorous sports such as atv,
utv and mx , demanded many attributes not found in other masks.
Turns out these requirements are the perfect match for lawn maintenance.
Comfort, ease of breathing and light enough to use through the hot work
days of summer, are only some of what puts Wolfsnoutï in a class of its own.
To learn more go to wolfsnout.com/landscaping 770 598 2994
Available in 8 colors. Retail $24.95
Wolfsnout® Lawn Mowing/Cutting Dust Mask
Memorial Day Weekend Coupon Code...Use code VET15 at check out..save 15%, valid thru the end of Monday!
Unrestricted filtered breathing means cooler comfort in the summer dust.
Exhaled air easily whisks away through the bottom while you play!
Will NOT cause LENS FOG related to restricted air flow forcing breath under eye wear.
Does not trap heat/Co2 like fabric, paper and neoprene.
Can not cause discomfort to the bridge of your nose, or pinch your nose closed.
Turns with your head, and does not work against your neck. You get full range of motion.
The perfect fit with any helmet & goggles.
Extra soft moister wicking face seal.
Unbeatable comfort.
Washable and reusable...A lasting value.
Unbeatable Performance 100% Guaranteed!
USE code LS10 at check out to save $$$
The Wolfsnoutï mask fits under your nose and over your mouth. So your nose and mouth are not confined in the same compartment. This unique design combined with our depth
loading filter foam, allows for a super easy breathing feeling. It does not trap hot C02 like the paper throwaways. Your exhaled air whisks easily away. Perfect for breathing at a
fast paced breath. Spring through Fall, the light weight design can be beat in the Summer heat. The super soft face seal, and nose filter provide comfort for all day use. It will not
clog when wet from sweat, like paper masks. Also, since it fits under your nose, it never vents under your goggles or glasses, fogging them up. Clean up is a snap, simply wash it
out with mild soap and cold water, squeeze excess water out, and let it dry over night. Mask can be used wet. If taken care of, the Wolfsnout mask can last several years
(depending on use) saving you money, with comfort that cannot be beat.
The Wolfsnout mask was invented and is produced in the USA. It was originally designed for ATV, UTV, Mx and other offroad sports where breathe ability was a must. As
the off-road community embraced this product it quickly became apparent that it was the perfect landscaping dust mask.
The Wolfsnout® mask can't be beet in the summer heat!
Re: Wolfsnout landscaping / Mowing Dust Mask
A couple of guys using the landscaping dust mask by Wolfsnoutï½®. They say they use them mowing trimming and blowing most every day.
These guys are professional landscapers.
