Wolfsnout Trimming / Mowing Dust Mask
   / Wolfsnout Trimming / Mowing Dust Mask #1
Wolfsnout
Advertiser
Lilburn GA
vendor
WOLFSNOUT MOWING, TRIMMING, BLOWING MASK
Washable and Reusable. With a super Soft Moisture Wicking Face Seal
Are you sick of breathing grass and dirt while you work?
Can't stand the paper masks that get wet, clog and fog your glasses?
One Wolfsnout mask can replace hundreds of the throwaways
we all hate so much and offers great comfort from spring through fall.
Finally everything you would not expect from a dust mask.
The patented under nose filter foam system separates your nose and
mouth for a superior free breathing feeling.
The Wolfsnout dust mask was originally designed for and is #1 for
off road riding. The requirements for these rigorous sports such as atv,
utv and mx , demanded many attributes not found in other masks.
Turns out these requirements are the perfect match for lawn maintenance.
Comfort, ease of breathing and light enough to use through the hot work
days of summer, are only some of what puts Wolfsnoutï in a class of its own.
To learn more go to wolfsnout.com/landscaping 770 598 2994
Available in 8 colors. Retail $24.95
Wolfsnout® Lawn Mowing/Cutting Dust Mask
Memorial Day Weekend Coupon Code...Use code VET15 at check out..save 15%, valid thru the end of Monday!
Unrestricted filtered breathing means cooler comfort in the summer dust.
Exhaled air easily whisks away through the bottom while you play!
Will NOT cause LENS FOG related to restricted air flow forcing breath under eye wear.
Does not trap heat/Co2 like fabric, paper and neoprene.
Can not cause discomfort to the bridge of your nose, or pinch your nose closed.
Turns with your head, and does not work against your neck. You get full range of motion.
The perfect fit with any helmet & goggles.
Extra soft moister wicking face seal.
Unbeatable comfort.
Washable and reusable...A lasting value.
Unbeatable Performance 100% Guaranteed!
USE code LS10 at check out to save $$$
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
20" Sea Container (A47384)
20" Sea Container...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
