Woa!!!!
/ Woa!!!! #1
AndyG
SW Indiana
I had a little trouble stopping my TC 40 last weekend. I was headed down hill and hit the brakes. The rear wheels locked but the front ones kept turning. Is there a way to make the front wheels stop when the brake pedal is applied.
/ Woa!!!! #2
</font><font color="blue" class="small">( Is there a way to make the front wheels stop when the brake pedal is applied. )</font>
Yes, have it in 4WD.
/ Woa!!!! #3
Andy,
Is this a gear or hydro. If it was a gear keeping it in a lower gear should hold you back from going too fast, in fact the hydro should also if in a lower gear. Sometimes we get rolling too fast when we put the clutch in and let the tractor free wheel. If going downhill on a steep slope with a load behind you it doesn't hurt to have it in 4 wheel also.
Now after you clean your shorts you just have to get back on your tractor and hit that hill again.
/forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
murph
/ Woa!!!!
Sorry, it is a hydo tractor with supersteer and sensitrak (sp?)
/ Woa!!!! #5
Go down hills in LOW range and 4wd engaged, you'll find you can decend in a controlled manner. Go down in MED or HIGH range and 2wd and you just have to hang on and hope.
/ Woa!!!! #6
Did you have weight on the front of the tractor - i.e. something in the bucket? If so, there was probably only a little weight on you back tires, hence the ride down the hill. Using 4WD is a good idea, but you should also be going backward down a hill when you have a load on the front. If you go down forwards the center of gravity moves forward. The steeper the hill the farther forward it moves.
/ Woa!!!! #8
</font><font color="blue" class="small">( If it had sensitrak shouldn't 4WD have come into play automatically? )</font>
Can't say if they are suppose to, but mine doesn't. If I go down a steep hill my back tires will rotate opposite directions. One will go forward and the other will try and go backwards. I have learned that even just mowing on my steep hill going down I have to put it in 4 wheel or I will rip the yard up.
murph
/ Woa!!!! #9
I had this happen with my Hydro and found that if I press on the forward pedal ever so slightly that it would prevent this from occuring. The first few times you do this you as if you are going to go for the ride of your life but it actually slows you down and prevents you from both rolling faster or skidding down the hill. It seems as if you have shifted into low gear.
/ Woa!!!! #10
Murph I'm no New Holland tech but might you have some other problem? We have more than a few slopes on our property including the back side of the dam which we mow and the R4s have never lifted the turf (yet). Most of the time it's low range and very little pressure on the HST pedal and the transmission seems to keep the tractor stable on the descent. We mow going down as well as up the backside, it's a real rush but it's far from a free wheel ride.
I can count on one hand the number of times that the TC-40D has been manually locked in 4WD in the year+ that we have had it. Normally the sensitrak does the deed for us.
/ Woa!!!! #11
My sensi-trac has always kicked in when needed except for going down the hill. When I do go down the hill I do keep my foot on the hydro a bit but I still have to hit 4 wheel or it will tear it up pretty good. I watched my son drive down once and I notice the one wheel trying to back up while the other went forward. If I put it in 4 wheel then I am ok, now my slope is so steep I don't dare go sideways on it or I'm a history. If it is really dry then I am ok I can go down without 4 wheel. If I have the loader on I have to have it in 4 wheel.
Maybe I should give my dealer a call. I guess I just thought it to be normal with one wheel trying to go opposite. I have seen that so many times on other vehicles/tractors etc that I never thought much about it having something wrong.
murph
/ Woa!!!! #12
</font><font color="blue" class="small">( I watched my son drive down once and I notice the one wheel trying to back up while the other went forward. )</font>
Murph, I'm certainly not an expert on our differentials, but I'm wondering if your one wheel reversing might have something to do with your problems of getting the differential lock to release properly?
Also, if you've ever had a car jacked up in the rear with both wheels off the ground and the transmission in gear so the drivetrain won't move, you can rotate one wheel and the other one will rotate in reverse. If you are going downhill and your tractor is in low range on the hydro, it might be that the drivetrain can't turn easily so one wheel with the lowest traction will actually turn backwards. If traction was exactly equal, I bet both wheels would slip. If you put the transmission into a higher gear, the drivetrain will cause the hydro to attempt backpumping a little and let the drivetrain rotate so that both rear wheels can turn.
This is just a "gut" feeling based on what I've seen with drivetrains and realizing that it's almost impossible to make a hydro drivetrain backpump. That's why when you lift the pedal, the tractor stops on a dime without braking. What do you think? /forums/images/graemlins/confused.gif
/ Woa!!!!
You folks have given some good info. I was wandering about stopping all 4 wheels using the brake pedal. From Murph's description it sounds like I need to lock 4wd in.
/ Woa!!!! #14
Doesn't the manuel recommend putting the tractor in 4wd lock when traversing steep slopes?
/ Woa!!!! #15
I have witnessed the same phenomenon (wheels turning in opposite directions going down hill) on a JD hydro.
This seemed to only happen when there was major slippage on the tires. I think it is related to the differential more than anything to do with the hydro.
I have spun the rears on gear tractors while there jacked up and they also turn in opposite directions. I haven't noticed if they rotate in opposite directions while sliding down hill yet. Not something I would willing experiment with either. /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
/ Woa!!!! #16
Jinman,
I am thinking more just the differential. If I jack up the back of the tractor and push one wheel one direction the other goes the opposite direction. This may only happen during slippage when on the ground. I am planning on stopping at my dealers this week-end and see what he says about it. I remember when I test drove a TC18D when I was buying my 21 the dealer drove down a wet steep hill and had the same problem. One wheel looked like it was trying to go backwards and the dealer was trying to get the differential lock in, but he couldn't find it. I thought he was going to tip the tractor over.
As far as my differential lock. I have not dug into it yet but I am thinking the linkages just need a good lubing up. The tractor sits outside all summer and then inside in the winter. I have not used the differential lock in close to a year. So I am hoping it is more linkage related. I even kind of remember it was a pain to get it into lock. I had to step pretty hard.
murph
/ Woa!!!! #17
</font><font color="blue" class="small">( I have witnessed the same phenomenon (wheels turning in opposite directions going down hill) on a JD hydro.
I have spun the rears on gear tractors while there jacked up and they also turn in opposite directions. I haven't noticed if they rotate in opposite directions while sliding down hill yet. Not something I would willing experiment with either. /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif )</font>
It's all about least resistance. One wheel spins backwards, the other wheel can spin 2x as fast & you go down the hill 2x as fast, for only one wheel slipping. The pull of gravity vs the resistance of the wheels - one wheel slipping 2x as fast backwards offers less resistance overall.
You realize going down the hill facing forward, your ag tire is actually working 'backwards', it is as if you had the wheels mounted the other way, with the tread facing wrong. It is real easy to lose traction that way.
--->Paul
2006 Takeuchi TL150 Compact Track Loader Skid Steer (A59228)
2006 Takeuchi...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2007 TUG GPU 400/60 28V 97kW Towable Diesel Generator (A59228)
2007 TUG GPU...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61306)
Midwestern...
2022 Ford F-150 Ext. Cab Pickup Truck (A59230)
2022 Ford F-150...
excavator trenching bucket- one bucket per lot (A61306)
excavator...
