Oil & Fuel Wix Hyd and Fuel filters for CK4010 HST
   / Wix Hyd and Fuel filters for CK4010 HST #12
2016 CK4010H
I bought Baldwin oil filters (2) for my l3800 changed the oil and filter The relief valve was chattering away when the tractor was cold so I went back to Kubota filters Its fine now I just go to dealer for my its not worth the grief, They have all the filters and I get to look at new tractors when I'm there:)
Sometimes the numbers just don't cross over:confused3: How old is the tractor?
2016 CK4010H
BTW... called the dealer and here were their prices:
Oil filter - E6201-32443 Dealer: 9.15
HST Filter - T5855-46531 Dealer: 27.99
Hyd Filter - T2185-38031 Dealer: 32.40
Fuel Filter - F6800-16411 Dealer: 5.71
Air Filter - E7230-11081 Dealer 37.26
Doesn't seem too bad to me...
   / Wix Hyd and Fuel filters for CK4010 HST #14
2016 CK4010H
Close to my kubota, oil was 10.20 I'd have to look the rest up but not bad. You should see if they a inner air filter for your tractor
Good to know... I may do the same, I had just heard that Wix filters are generally high quality... not saying that Kioti's/Daedong/Donaldson's/whoever's aren't, I just don't see paying extra for the same or better quality filter.
   / Wix Hyd and Fuel filters for CK4010 HST #16
I'm going to cut the baldwin filter open when i change the oil on the new machine in a couple of weeks to see what's different inside from the kubota filter
Well, I asked the dealer if it had an inner filter, but he said he would have to look it up and I needed to get off the phone and couldn't wait... I did tell him I had pulled the outer and didn't see any other filter... where is the inner one located?
   / Wix Hyd and Fuel filters for CK4010 HST #18
I use the Donaldson phone number and call them up.
in my case the part number of the Donaldson filter itself is still new so I recorded it.
If you have that number it will help, or call them up. They have been pretty helpful thus far for me.
   / Wix Hyd and Fuel filters for CK4010 HST #19
Its smaller goes in the filter housing first then the outer filter, Mine did not come with one new I added it later you might not be able to do it on your tractor
   / Wix Hyd and Fuel filters for CK4010 HST #20
Depends on the year model. My CK4010 (2016) did not have an inner filter but did notice the 2017/18s do.
Dealer should help clear that one up.
2013 Ford F-750 Truck, VIN # 3FRXF7FL2DV789551 (A57453)
2013 Ford F-750...
Caterpillar 259D (A57148)
Caterpillar 259D...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2008 Ford F-250...
