Oil & Fuel Wix Hyd and Fuel filters for CK4010 HST
   / Wix Hyd and Fuel filters for CK4010 HST #12
2016 CK4010H
I bought Baldwin oil filters (2) for my l3800 changed the oil and filter The relief valve was chattering away when the tractor was cold so I went back to Kubota filters Its fine now I just go to dealer for my its not worth the grief, They have all the filters and I get to look at new tractors when I'm there:)
Sometimes the numbers just don't cross over:confused3: How old is the tractor?
2016 CK4010H
BTW... called the dealer and here were their prices:
Oil filter - E6201-32443 Dealer: 9.15
HST Filter - T5855-46531 Dealer: 27.99
Hyd Filter - T2185-38031 Dealer: 32.40
Fuel Filter - F6800-16411 Dealer: 5.71
Air Filter - E7230-11081 Dealer 37.26
Doesn't seem too bad to me...
   / Wix Hyd and Fuel filters for CK4010 HST #14
2016 CK4010H
Close to my kubota, oil was 10.20 I'd have to look the rest up but not bad. You should see if they a inner air filter for your tractor
Good to know... I may do the same, I had just heard that Wix filters are generally high quality... not saying that Kioti's/Daedong/Donaldson's/whoever's aren't, I just don't see paying extra for the same or better quality filter.
   / Wix Hyd and Fuel filters for CK4010 HST #16
I'm going to cut the baldwin filter open when i change the oil on the new machine in a couple of weeks to see what's different inside from the kubota filter
Well, I asked the dealer if it had an inner filter, but he said he would have to look it up and I needed to get off the phone and couldn't wait... I did tell him I had pulled the outer and didn't see any other filter... where is the inner one located?
   / Wix Hyd and Fuel filters for CK4010 HST #18
I use the Donaldson phone number and call them up.
in my case the part number of the Donaldson filter itself is still new so I recorded it.
If you have that number it will help, or call them up. They have been pretty helpful thus far for me.
   / Wix Hyd and Fuel filters for CK4010 HST #19
Its smaller goes in the filter housing first then the outer filter, Mine did not come with one new I added it later you might not be able to do it on your tractor
   / Wix Hyd and Fuel filters for CK4010 HST #20
Depends on the year model. My CK4010 (2016) did not have an inner filter but did notice the 2017/18s do.
Dealer should help clear that one up.
Kubota RTV X900 (A53317)
Kubota RTV X900...
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
