Within the realm of possibility?
   / Within the realm of possibility? #1
ole mcdonald
I received a Massey Ferguson sickle bar mower ,but it seems to be a little to wide for my Yanmar 1610 D.Would it be possible to put on new lift bars that were maybe 6 inches longer?Or any other suggestions would be welcome.The thing that rides under the left side lift arm scrapes my rear tire.What if I shortened the anti sway chains?They still have slack in them even though they are as tight as they go.
   / Within the realm of possibility? #2
Somebody put longer arms on mine along with the oversize tires. That should work fine.
   / Within the realm of possibility? #3
Have you tried turning the mower's pins to the inside? That works on a lot of mowers. You can also swap the rear wheels to gain a little extra width if that has not already been done. We also have some offset arms that might help some. They reach out around the rear tires -
Yanmar Tractor Parts: Lift arm - 27.75 centers
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks Aaron,the pins are to the inside already and the tires are as wide as they go ,so I will probably have to go with the new lift arms.
   / Within the realm of possibility? #5
Aaron......would the offset bars work on a 1510D?
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2001 Volvo (A50120)
2001 Volvo (A50120)
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
Ditch Witch 350SX Diesel Ride-On Hydraulic Trencher (A50322)
Ditch Witch 350SX...
