Within the realm of possibility?
   / Within the realm of possibility? #1
ole mcdonald
I received a Massey Ferguson sickle bar mower ,but it seems to be a little to wide for my Yanmar 1610 D.Would it be possible to put on new lift bars that were maybe 6 inches longer?Or any other suggestions would be welcome.The thing that rides under the left side lift arm scrapes my rear tire.What if I shortened the anti sway chains?They still have slack in them even though they are as tight as they go.
   / Within the realm of possibility? #2
Somebody put longer arms on mine along with the oversize tires. That should work fine.
   / Within the realm of possibility? #3
Have you tried turning the mower's pins to the inside? That works on a lot of mowers. You can also swap the rear wheels to gain a little extra width if that has not already been done. We also have some offset arms that might help some. They reach out around the rear tires -
Yanmar Tractor Parts: Lift arm - 27.75 centers
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks Aaron,the pins are to the inside already and the tires are as wide as they go ,so I will probably have to go with the new lift arms.
   / Within the realm of possibility? #5
Aaron......would the offset bars work on a 1510D?
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
LED Peterbilt Sign (A50324)
LED Peterbilt Sign...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
20' Deer Gates (A50121)
20' Deer Gates...
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
