Within the realm of possibility?
   / Within the realm of possibility? #1
ole mcdonald
I received a Massey Ferguson sickle bar mower ,but it seems to be a little to wide for my Yanmar 1610 D.Would it be possible to put on new lift bars that were maybe 6 inches longer?Or any other suggestions would be welcome.The thing that rides under the left side lift arm scrapes my rear tire.What if I shortened the anti sway chains?They still have slack in them even though they are as tight as they go.
   / Within the realm of possibility? #2
Somebody put longer arms on mine along with the oversize tires. That should work fine.
   / Within the realm of possibility? #3
Have you tried turning the mower's pins to the inside? That works on a lot of mowers. You can also swap the rear wheels to gain a little extra width if that has not already been done. We also have some offset arms that might help some. They reach out around the rear tires -
Yanmar Tractor Parts: Lift arm - 27.75 centers
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks Aaron,the pins are to the inside already and the tires are as wide as they go ,so I will probably have to go with the new lift arms.
   / Within the realm of possibility? #5
Aaron......would the offset bars work on a 1510D?
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2017 Bobcat E32i Mini Excavator (A50322)
2017 Bobcat E32i...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
