Wiring up a rear work light
   / Wiring up a rear work light #11
So on my 2018 Ck3510hse I have the bullet style plugs on the right but on the left I have different plug. This plug doesn't have power. Now looking under the cover on the left side of the steering wheel I found 2 more bullet plugs blue and black that arnt capped . I looked in the fuse box and there is a place for optional beacon light relay and a fuse also. I have more switch spaces on my dash. So I guess my question is I'm wondering if these wires are all part of the optional beacon and if they can be used for rear work light.
   / Wiring up a rear work light #12
So today I did some testing the plug on the left next to the seat is for the optional beacon . There is a connector tyrap to the steering wheel that with the right switch and relay you can operate work lights from the dash.
   / Wiring up a rear work light #13
Interesting. There is a blank switch position on my dash. I'll have to look.
Here is what I found so far on the back of my new to me 2016 5010HS just above the PTO. Three connectors - left to right: A three pin (white plastic), a 6 position with 5 wires, and two bullets.
- The three pin is ground, Constant Hot, and hot when ignition turned to ACC or on.
- The 6 position is clearly for a trailer. Gnd, left signal, right signal, park lights and a 12v hot...all available when ignition is on.
- The bullets are gnd and 12v hot when ignition-on.
My plan is to install a rear facing work light and connect it to the bullet set through a switch positioned in a blank beside the seat. This keeps the wiring short and easy. More to come when the switch arrives.
I will mention that in addition there are a set of bullet connectors on the left and right that are not active in any ignition position. Not sure what they are for. Anyone know?
   / Wiring up a rear work light #14
On my NX4510 HST I wired in my rear LEDS to the right side tail light. I installed a switch on the right rear tail light panel that has two places for a switch.
   / Wiring up a rear work light #15
JimR: Do you happen to have a link or name of the switch you bought that fits that spot? Would be a perfect spot
   / Wiring up a rear work light #16
I took the plug out and went to either Auto Zone or Advance Auto parts and got a rocker switch. I made a new hole in the plastic plug with my Dremel tool to fit the new switch. It was very simple to do.
   / Wiring up a rear work light #17
I just drilled the rail behind the seat for a round switch. Very easy and there are already a zillion "pilot holes" to choose among if you want. Just move the harnesses mounted under it out of the way first - which probably already are if you're getting at the OEM work light wire.
JimR's way very clean too. Sounds like either can be reached from the seat just fine.
   / Wiring up a rear work light #18
Yup, I can reach my switch easy. mounting on the rail would move it closer. i wanted it enclosed inside the rear light cover.
   / Wiring up a rear work light #19
I have a single work light mounted on the bracket that holds the turn signal. There is a simple toggle switch on the bracket also. Power from the pigtails found under the fender. Not the best picture to show the light - but it is there. More than enough light for any night time grading I might do.
   / Wiring up a rear work light #20
I like that set up! Where did you get the lights?
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55315)
Koyker Loader...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
