wiring toggle switch
   / wiring toggle switch #1
musselmark
grand tracadie PE
'05 NH TN75DA
Not tractor related but I have a little 50 Giovanni quad and it has a 4 pin 2 position key switch, we lost the keys and I want to replace it with a simple toggle switch. There are 4 wires, one key position completes 2 wires (black and red) and leaves other 2 ( green and black/white) open, other position does the opposite, completes green and white/black) and leaves red and black open. What kind of switch do i need, I am thinking a triple throw double pole 6 pin (on off on) and only using 4 of the pins. Is there any type of simple toggle with just 2 positions that could do this?
   / wiring toggle switch #2
With a toggle switch you will still need a momentary switch for the starter.
I would just replace the switch.
   / wiring toggle switch #3
Use a dpdt w/center off switch, and bridge the center common contacts.
Thanks gyus, I ended up using a dpdt 2 position (on-off) switch. center right and upper right for one pair and center left and lower left for other pair.
   / wiring toggle switch #6
Looks like you got it. DPDT was what I was going to say but you figured it out. Just out of curiosity, what are the two wires that close when the switch is off?
   / wiring toggle switch #7
Probably an anti theft device. Shorts out the ignition so it can't be hot wired...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
John Deere 6120E (A50323)
John Deere 6120E...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
UNUSED INDUSTRIAS AMERICA HI100T HYD TILT LAND LEV (A51247)
UNUSED INDUSTRIAS...
