Wiring the Diverter solenoid
/ Wiring the Diverter solenoid #1
AlbionWood
Albion, CA
Ford NH 1920
Where should I tap into the electrical system to power the solenoid on a hydraulic diverter valve?
This one has a little LED in the Hirschmann connector, so I can tell if it's on, and if I stay with the momentary pushbutton switch I can't really run the battery down. So, I could connect directly to the battery, but then I'd want an inline fuse.
Or, I could tap into the fuse block, on a key-switched circuit (like lights). Or somewhere else.. (Would I need a diode?)
If you have one, where do you get 12v?
/ Wiring the Diverter solenoid #2
I ran mine right off the battery with a fuse in line. It was just as easy that way for me.
Thanks... Bowhunters get extra credit with me!
2017 International HX620 Quint Dump (A62613)
2017 International...
1770 (A64280)
1770 (A64280)
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2022 EZ-GO ELITE...
2003 International 4300 National Crane 326A 7 Ton Straight Boom Crane Truck (A61573)
2003 International...
