Wiring schematic
/ Wiring schematic #1
Gryphyn454
Florida
2019 Rural King RK24
Has anyone seen wiring schematics for the RK 24? My preheat quit working and I have no idea where to go after the fuse block. The fuse is good.
/ Wiring schematic #2
I had a very similiar problem with my RK 24 where the glow plug light on the dash would not illuminate and the glow plugs would not work (no preheat cycle).
I cleaned the contacts at the preheat relay (middle relay in a group of three located on the r/h side of engine above the oil filter) and the contacts on the ignition switch. It has worked fine ever since.
The schematic that you need is for the TYM T254 series. Don't remember the full number but is the TYM version of an RK 24.
/ Wiring schematic
Thanks that is start. I'll see what I can find with h relay and TYM model
12x20 Car Port (A65640)
12x20 Car Port...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
2 Bottom Plow (A62613)
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
