Price Check wiring question
/ wiring question #1
Stelly1227
Belarus 250 as
I recently got a Belarus 250as. Well it wouldn't start it had to be pulled to start well it somked really bad. Well I put new rings on it. But anyways I'm wanting to fix and use only what I need. I was wondering if anyone knows how o wire up the fuel gauge. I have the factory gauge all I have to do is send power to the sensor and the. A wire back to the gauge or what do I have to do. Thanks
/ wiring question #2
Stelly1227
I know nothing about Belarus other than I nearly bought one many years ago and it had to be pulled / bump started. The fuel gauge is probably simple level wiring so if you look at any 1960 /70 North American car setups it should be similiar in concept.
Craig Clayton
/ wiring question #3
You can pick up a universal fuel gauge and install it in your tank, It comes with a sending unit and gauge that are matched to each other. easy to install, I did it to mine and the new gauge works fine.. The wiring on the 250 looks like a mess, but is easy to follow, if you have the savy to wire a 3 way switch you will have no problem working on the 250.
I do have the wiring diagram, but you need a russian dictionary and good eyes to follow it :laughing:
I just take it one wire at a time......:thumbsup:
Case skid steer wheels and tires (A63689)
Case skid steer...
More info coming soon (A61574)
More info coming...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59912)
2025 ALCOM XPRESS...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
