wiring problem with LED's
/ wiring problem with LED's #1
budepps3760
Montgomery, Al
Mahindra 2810
Have a problem and hope someone can help me. I installed a 10" LED bar on my tractor about a month ago mounting the bar and running the cable through the body etc. I was not able to finish due to time management however before I left for the day I touched the wires to the battery terminals to make sure I had no bare wire issues and light came on fine with no problems. I disconnected the negative battery terminal so I would not have a dead battery upon my return. Went back today to drill instrument panel for switch and finish running thermal tubing through engine compartment however I could not get the light to operate under any circumstances. The switch has a red, blue and black wire connection. If I remove the blue wire from the 3 prong switch the switch itself will illuminate however the light bar will not come on. With all 3 wires attached to the switch the switch will not illuminate and the bar still will not come on. The switch does not illuminate as brightly it seems as it did a month ago however the tractor cranks right up and runs fine and so it does not appear to be a discharged battery. Any suggestions as to the problem is? :confused:
/ wiring problem with LED's #2
I'm thinking since it's an illuminated switch the three wires are red+12V from the battery, blue +12V to the light and black - ground for the indicator light. That's just a guess, check it with a multimeter so you don't fry anything.I aaume the light will work if you touch the wires to the battery?.....Mike
/ wiring problem with LED's #3
Does the the light bar come on if you bypass the switch?
Do you have a wiring diagram for the switch?
/ wiring problem with LED's #4
If the LED's don't have reverse polarity protection. They are smoke by now.
Is there a guarantied chassis return/ground connection ALL the way back ?
/ wiring problem with LED's #5
.... and the cheap units don't. LED's being electronically excited are very reverse polarity touchy. Your telling statement is....I touched the wires to the battery terminals to make sure I had no bare wire issues and light came on fine with no problems.
When touching the red and black wires to the battery terminals only the switch illuminates and not the light bar.
There is a relay in the wiring harness however it is not attached to the chassis, only hanging down currently. There is a metal bar with a screw hole that I can attach to the frame somewhere in case that is a ground however I removed the metal bar from the relay housing because I needed to drill the hole into a larger diameter to accept a larger bolt however the metal bat is not attached to the relay physically. I mean to say that the metal strip slides into a groove on the side of the relay and thus that metal strip does not make electrical contact with the relay itself and thus could not serve as ground for the electrical connection. That is why I held off attaching the relay to the chassis until I need to pull the entire writing harness.
How would I bypass the switch to test the light bar? Just alligator clip 2 wires to the light bar terminals itself? I do not have a wiring diagram (I noticed one imprinted on the relay itself) and of course I did not take a picture of it today when I saw it. I may have to run back to the farm tonight and take a picture of it and post. I was thinking off running by the Indian casino which is half way there and do that would make a good excuse to head that way again.
No ground that I am aware of. However when I tried the lights last time I am not aware of them being grounded at that time either. I am starting to think that maybe that metal strip must be attached to the relay switch and bolted down somewhere.
Actually it is a Black Oak led. I paid $207.00 for the led and bracket. Anything but cheap.
/ wiring problem with LED's #8
Just so you know. LEDs are diodes so they have their own inherent reverse polarity protection built in. Diodes only allow current to flow in one direction so if you hook them up backwards they just don't work but no current flows so no damage. To cook them you have to exceed the voltage rating and allow too much current to flow, then they will live for only one brief shining moment and shine no more.
/ wiring problem with LED's #10
Thats not all that much. I run CREE 9 high output LED lights forward facing on both my tractors and they were each 150 per lamp. 300 for the front, 300 for the rear times 2 units.
/ wiring problem with LED's #11
But.... It's the circuitry associated with the LED's that is polarity sensative.
LEDs are typically wired in series for voltage distribution and if there is anything to limit current it's usually a resistive device. You'd almost have to go out of your way to make it polarity sensitive to where damage would occur if you hooked it up bassackwards.
/ wiring problem with LED's #13
Didn't protect the LED's that we purposely reversed during lab class in college.
Here are 2 pictures that I took of the wiring diagram from the case of the relay. I brought the tractor in to charge it. Sanded a few areas to try and get a better ground location but still no luck. I can't direct wire to the battery as I would have to open the bar up to gain access to wire to clip onto and thus my warranty would be gone at that point. Going to take the battery up in the next couple of days to see if that helps and also to see if I can find a method of direct wiring before I send it back to the manufacturer. Lifetime warranty and so might as well take advantage of it if I can't scratch my hnead and figure something out.
/ wiring problem with LED's #15
Did this come as a complete unit including the lighted switch?
Any instructions?
Yes came as a unit with wiring harness already connected. The instructions basically said to hook red to positive and black to negative.
/ wiring problem with LED's #17
So I guess you added longer wires.
Did you run the positive through a fuse?
It should be easy to find the problem with a multimeter.
/ wiring problem with LED's #18
Looks to me from the diagram, that the relay is a normally on. When you energize the relay it opens the contact. So turn on the relay, no power to light bar. Yet the light bar is off because the switch is off.
/ wiring problem with LED's #19
Yep, I noticed that also, so I googled the part number and it showed a normally open 5 pin relay.
So either the diagram or the part number is wrong.
It is a standard automotive relay and pin 87 is NO, 87a is NC.
There is also a 4 pin version:
I pulled the cap off the relay and it is a 4 pin relay and not a5 pin. Yes I did run longer wires and the red wire does have a fuse in it.
Just so happens I bought a Klein Tools 1000 mm multimeter last week as I needed to check the capacitors on a phase shifter that was used for dad's 3 phase equipment I his cabinet shop. I have limited knowledge on electrical circuits so what is your recommendation in going about checking the relay? Walk me through the process and I will test Tuesday when I return to the farm with the tractor battery recharged.
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
2014 Ford Expedition SUV (A64557)
2014 Ford...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
