wiring on starter/solonid
   / wiring on starter/solonid #1
beagle man
missouri
jimma
I took the starter off and now when I hit the key nothing, can jump with screw driver fires off/ runs,, I think I got some wires crossed, and yes I should have paid more attention or took pictures,,, can someone take a picture and post for me of a farm pro 24/25 starter that shows the wire hook up the engine is a Y 285, Please.
New Deal, just back from barn, decided to pull the tractor out of the shed and into the barn, well no lights, no horn, no gauges working, must be a fuse I can not find, Now to look for the book. Unless someone knows of a spot for me to look,,,,or has had this problem and can tell me what they think it is.... Thanks
   / wiring on starter/solonid #4
Sometimes at the starter solenoid is a special wire called a fusible link which is a form of fuse to protect the entire electrical system,
It will look like a wire so it is sometimes hard to distinguish.
Google "Fusible link" and be better informed..
Post the picture I have requested.
Dave M7040
Thanks to all , I found the Book, Now in a safe place, I had a white wire on the ground and it should have been on the hot side of the starter. it all works now, People put them books in a safe place. Thanks Dave I appreciate your response.
michael j.
   / wiring on starter/solonid #6
Had you posted a picture like requested, I'm sure your problem would have been solved much sooner.;)
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
7046 (A50322)
7046 (A50322)
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
