wiring on starter/solonid
   / wiring on starter/solonid #1
beagle man
missouri
jimma
I took the starter off and now when I hit the key nothing, can jump with screw driver fires off/ runs,, I think I got some wires crossed, and yes I should have paid more attention or took pictures,,, can someone take a picture and post for me of a farm pro 24/25 starter that shows the wire hook up the engine is a Y 285, Please.
New Deal, just back from barn, decided to pull the tractor out of the shed and into the barn, well no lights, no horn, no gauges working, must be a fuse I can not find, Now to look for the book. Unless someone knows of a spot for me to look,,,,or has had this problem and can tell me what they think it is.... Thanks
   / wiring on starter/solonid #4
Sometimes at the starter solenoid is a special wire called a fusible link which is a form of fuse to protect the entire electrical system,
It will look like a wire so it is sometimes hard to distinguish.
Google "Fusible link" and be better informed..
Post the picture I have requested.
Dave M7040
Thanks to all , I found the Book, Now in a safe place, I had a white wire on the ground and it should have been on the hot side of the starter. it all works now, People put them books in a safe place. Thanks Dave I appreciate your response.
michael j.
   / wiring on starter/solonid #6
Had you posted a picture like requested, I'm sure your problem would have been solved much sooner.;)
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
New Holland TN65S (A50123)
New Holland TN65S...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
