Wiring Help on BX23
   / Wiring Help on BX23 #1
rlsmith
Bronze Member
Northern Ohio
06 BX 23, 1956 AC Little G, JD 1025R
Ok I gone and done it on my BX23. Between the mud, sticks and ? the wires for the rear lights/turn signals got a bit messed up along with my fuel gauge has stopped working. Ok pulled and ripped apart. I got the lights to work & turns but still no fuel gauge. Any help would be great.
   / Wiring Help on BX23 #2
Fuel gauge is reliable and easy to test (attached). If you don't get battery voltage, figure out which terminal is bad and chase that wire.
If gauge passes test, find the sender wire from tank level sensor under the dash. Wiring diagram says it is yellow and blue and goes to the 'S' terminal on gauge. With it disconnected from gauge, check for continuity to ground. Should be anywhere from 1 ohm (full tank) to 155 ohm (empty tank). If it shows open, the wire break is between your test point and the tank sensor (or the sensor is bad, which is a bit of surgery).
Good luck!
2003 Lincoln Aviator (A50515)
2003 Lincoln...
2013 Dodge Grand Caravan SE Van (A50324)
2013 Dodge Grand...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
