Wiring electric winch plug for Log arch winch
   / Wiring electric winch plug for Log arch winch #11
Hey Piston,, Do the Buds go flat from all the bouncing around ???
   / Wiring electric winch plug for Log arch winch #12
On that size winch I would definitely go to the larger size. That way you can also make up a set of booster cables that fit the plug.
I have one setup where I've mounted a second battery near the winch (8000lb)and use the 7pin plug to keep the battery charged.
Not really, I take it very slow when using the arch so it's not bad, for the most part I'm driving up a paved road which of course is very smooth. Those muffler clamps are the perfect size for cup holders! :thumbsup:
That's a good idea about the jumper cables, I might order some new connectors for that bigger size up. Do I need any kind of inline fuse or something to that effect? I wouldn't think so but I don't know much about electricity :D
   / Wiring electric winch plug for Log arch winch #14
By using one on the tractor and one on the truck you can jump either by just plugging in.
If it was me I would play it safe and go with the higher amperage rated connectors.
I use the 350 amp connector for all battery connections as with the winch or jumping a vehicle.
The booster cables I use have that type of connectors in-line on both ends.
The ends are adaptable for either use, Clamps or Plug-ins.
Also, I got an extension cable that plugs in just in case I can not get close enough with the shorter cables.
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Starts And Runs (A59228)
Starts And Runs...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
