Wiring electric winch plug for Log arch winch
   / Wiring electric winch plug for Log arch winch #11
Hey Piston,, Do the Buds go flat from all the bouncing around ???
   / Wiring electric winch plug for Log arch winch #12
On that size winch I would definitely go to the larger size. That way you can also make up a set of booster cables that fit the plug.
I have one setup where I've mounted a second battery near the winch (8000lb)and use the 7pin plug to keep the battery charged.
Not really, I take it very slow when using the arch so it's not bad, for the most part I'm driving up a paved road which of course is very smooth. Those muffler clamps are the perfect size for cup holders! :thumbsup:
That's a good idea about the jumper cables, I might order some new connectors for that bigger size up. Do I need any kind of inline fuse or something to that effect? I wouldn't think so but I don't know much about electricity :D
   / Wiring electric winch plug for Log arch winch #14
By using one on the tractor and one on the truck you can jump either by just plugging in.
If it was me I would play it safe and go with the higher amperage rated connectors.
I use the 350 amp connector for all battery connections as with the winch or jumping a vehicle.
The booster cables I use have that type of connectors in-line on both ends.
The ends are adaptable for either use, Clamps or Plug-ins.
Also, I got an extension cable that plugs in just in case I can not get close enough with the shorter cables.
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
24in Bucket Mini Excavator Attachment (A56857)
24in Bucket Mini...
WORK BOX FOR FORKLIFT (A52708)
WORK BOX FOR...
2004 MACK CH613 WATER TRUCK (INOPERABLE) (A58214)
2004 MACK CH613...
