Wire welder Spool Adapter Question
/ Wire welder Spool Adapter Question #1
NCMau
NC
MF 202/Ford 8N
Can any of you welders can tell me if a Lincoln 10 lb spool adapter can fit the spindle of an HF 170A wire welder? I am trying to use a 10 lb wire spool and as far as I know HF does't carry the adapter, but Home Depot carries a Lincoln adapter. I could check the measurements but It's a 30 miles drive for me.
/ Wire welder Spool Adapter Question #2
Can't say for sure but since the 2# spool is universal and the 10# spool is universal I think, yes.
/ Wire welder Spool Adapter Question #3
you got a welder, build you whatever adapter you need.
A buddy of mine was given 10 rolls of wire but it wouldn't fit his machine. 30 minutes later and a few parts cut out, some ingenious thinking, it fit like it was made for it.
I guess if I have to spend more than 5-6 dollars I would for sure.
/ Wire welder Spool Adapter Question #5
Give me 1/2 hour west coast ( 7:30 pst ) time and I'll measure the adapter in my lincoln 135 thus all you have to do is measure your machine.
Fred H.
O.k. Shaft size in my Lincoln is .635" ( some were between 1/2" and 3/4" maybe 5/8" ??? did not convert decimal to fraction ) Adapter is slightly larger than that , a little slop but not much . Length of adapter is 3" so I would think it would still fit and be able to close door on welder . Assuming you are talking about this product :
Lincoln Electric Wire Feed Welder Spindle Adaptor-KH720 at The Home Depot
Thanks Fred. My spindle is 5/8 so I should be able to use it.
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
Caterpillar 988B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 988B...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
Fork Extensions (A61572)
Fork Extensions...
