Wire welder Spool Adapter Question
/ Wire welder Spool Adapter Question #1
NCMau
NC
MF 202/Ford 8N
Can any of you welders can tell me if a Lincoln 10 lb spool adapter can fit the spindle of an HF 170A wire welder? I am trying to use a 10 lb wire spool and as far as I know HF does't carry the adapter, but Home Depot carries a Lincoln adapter. I could check the measurements but It's a 30 miles drive for me.
/ Wire welder Spool Adapter Question #2
Can't say for sure but since the 2# spool is universal and the 10# spool is universal I think, yes.
/ Wire welder Spool Adapter Question #3
you got a welder, build you whatever adapter you need.
A buddy of mine was given 10 rolls of wire but it wouldn't fit his machine. 30 minutes later and a few parts cut out, some ingenious thinking, it fit like it was made for it.
I guess if I have to spend more than 5-6 dollars I would for sure.
/ Wire welder Spool Adapter Question #5
Give me 1/2 hour west coast ( 7:30 pst ) time and I'll measure the adapter in my lincoln 135 thus all you have to do is measure your machine.
Fred H.
O.k. Shaft size in my Lincoln is .635" ( some were between 1/2" and 3/4" maybe 5/8" ??? did not convert decimal to fraction ) Adapter is slightly larger than that , a little slop but not much . Length of adapter is 3" so I would think it would still fit and be able to close door on welder . Assuming you are talking about this product :
Lincoln Electric Wire Feed Welder Spindle Adaptor-KH720 at The Home Depot
Thanks Fred. My spindle is 5/8 so I should be able to use it.
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
2018 Club Car Carryall 1700 4x4 Utility Cart (A61572)
2018 Club Car...
