Wire Welder Question
/ Wire Welder Question #21
Heres a problem i had with my Lincoln mig.I kept having to turn the pressure up
on my feed rollers to get it to work right.Finally,i took the wire guides out and boiled them (in water)for about 15 minutes.Then ,i took a piece of scrap welding wire
and kept working it thru the guides until it worked freely.Guess what,thats what the problem was.RUST BUILDUP INSIDE THE WIRE GUIDES.In my case it had nothing to do with the liner.
After i put it back together it worked like new.I dont know how your machine is set up but my Lincoln has two wire guides.One before the feed rollers and one after.Wont cost you much but your time to check it out.
Digger2
/ Wire Welder Question #22
Oh by the way......My wire guides were STEEL....there may be brands out there with plastic or nylon in them,in that case i would'nt boil them.
Digger2
Digger2
I have steel or brass guides on mine. I thought I had checked them but won't hurt to try again.
Not sure what fixed the problem, but problem solved for now. I took everything apart and cleaned piece by piece. Appears there was no one thing, just a combination of problems. Works great again. Thanks for the ideas.
/ Wire Welder Question #26
the answer to humidity problems is an old upright freezer gutted to be used as a cabinet with a light bulb. I put My welder in it with all electrodes and the mig when I'm not using it. A 15 watt bulb keeps it warm and humid free. Bill
/ Wire Welder Question #27
I just got a new liners for my old Miller matic 35, I dont use a wire welder much but I didnt want it sitting there, I had moth balled it for a about 2 years, not using it then got a liner. Its an old GA20C hose and gun. I didnt have 385 for a new 15 foot set up so I found a liner for 45 bucks. I got it in and set then had a small spool of wire. I hadnt been in the shop in a week and went out and used it without checking the wire and it started miss feeding, I panicked and check the wire sure enough it had spots on it bad and the liner blew out rust. It has a filter wiper but it was worn a little. I pulled the wire and blew out the liner. Then gave the end a few shots of PB Blaster. and ssquirted some blaster on the filter and i re crimped it. I unrolled more of the wire and found that I had gone past the rust I welded a bit with it and it fixed it.
/ Wire Welder Question #28
Here is another cheap wire cleaner before it goes into the brass (steel) guide. Take a squeezable ear plug hold it sideways to the point of the wire push the welding wire through it. Push the wire through the guide, ear plug stays tight on the inside putting firm but not to tight of a grip on the wire keeping dust and dirt out the guide and liner. Works better than the felt wire cleaners and throw it away when you change out the spool.
Slick idea!!!!!!!!!!!!!!
/ Wire Welder Question #30
That's a great idea!! My roll of .030 is about done, I'll do this when I change rolls!
/ Wire Welder Question #31
Sounds like another great use for WD40. :thumbsup:
Now if you could use Duct Tape to hold the door closed on the welder it would be a complete kit.
RC
Okay .... I have to confess that I once tried WD40 when I was struggling with feed issues (before tip change)
It made a very noticeable improvement.
I was careful to do quite a bit of non-critical welding until I felt that most of the WD40 was gone.
Sherweld
/ Wire Welder Question #32
I needed a quick repair and the only wire I had left at the time had some light rust spots. Big mistake, now I apparently have some of this on the inside of my cable liner, because I'm getting uneven feed on the wire. Any recommendations on cleaning the liner, or am I out the cost of a new liner.
Its the Tip...your welcome..
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
MARKER LIGHTS (A64276)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
