Wire size help
/ Wire size help
I have a 40amp relay with wire harness plug but the wires on the harness are not 10ga. Can I just use the blade type connectors that are made for 10ga wire and hook them directly to the relay instead of using the wire harnes plug that came with it
/ Wire size help #22
A wiring harness is just a tidy set of plugs with the wires already hooked up. No issues at all building your own as long as all the components are rated 40@ or higher. Or at least as high as the fuse you are going to put in. The fuse always needs to be rated equal or preferably less than the weakest component(s) in the circuit.
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2005 Ford F250 Super Duty XLT (A66408)
2005 Ford F250...
2022 EZ-GO ELITE...
