Wire size help
   / Wire size help
I have a 40amp relay with wire harness plug but the wires on the harness are not 10ga. Can I just use the blade type connectors that are made for 10ga wire and hook them directly to the relay instead of using the wire harnes plug that came with it
   / Wire size help #22
A wiring harness is just a tidy set of plugs with the wires already hooked up. No issues at all building your own as long as all the components are rated 40@ or higher. Or at least as high as the fuse you are going to put in. The fuse always needs to be rated equal or preferably less than the weakest component(s) in the circuit.
   / Wire size help
Sweet. Then thats what I'll do. Thanks for all the help
Tanker Trailer (A59230)
Tanker Trailer...
Deere 335P (A53317)
Deere 335P (A53317)
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
40 (A52708)
40 (A52708)
7021 (A55851)
7021 (A55851)
CASE 610 Sprayer System 2000 Gallons (A56438)
CASE 610 Sprayer...
