Winter Starting Question
/ Winter Starting Question #1
Dave01
NH
I'm looking out my window at 10 degrees this morning, got me thinking. I'm setting up the 2084 to plow. I'll run 5W30 dino oil. Does anyone use a block heater, or just crank it over and go? When I plowed with a JD 10 years ago it started but on very cold days it could be a struggle. Is there even a heater made for CC's?
/ Winter Starting Question #2
I have a GT2542 and live in North Eastern Connecticut.
I switched over to a 5W20 synthetic for the winter.
/ Winter Starting Question #3
I have a CC 7260. I bought a tank style heater at one of my local auto parts stores, and simply plumbed it up, no big deal. It does make start ups a lot easier on the tractor when it gets cold.
Corm
EDIT - Oops, just noticed your tractor isn't water cooled. Didn't notice that initially. In that case, I can't be much help to you!
/ Winter Starting Question #4
i don't use my tractors in the winter.but on super cold days i use a 4gal(or what ever it is)propane heater to warm up my snow thrower.I also use it for the air compressor.i keep it maybe 3 feet away or so.it only takes a few min.
I could use a space heater in a pinch, but if I was going to do it regularly would rather have a heater on the block. I suppose a dipstick heater might work but not a great solution either.
/ Winter Starting Question #6
Dave0 I suppose a dipstick heater might work but not a great solution either.[/QUOTE said:
Hi Dave01
What is a dipstick heater?
We don't get the snow here in NE Iowa like you all get.Today we got about 8".But it can get cold.Wed we hit -19F air temp.
/ Winter Starting Question #7
Undercover - The dipstick heater is just what it's name implies. A heater that goes in place of the oil dipstick.
-19 is cooooolllllddd. Coldest I've seen yet this year is -8 driving through Vermont.
Diesel said it, just goes in place of your dipstick. They have a rap of possibly causing some fires, I've wondered how valid it is. Anything that gets real hot in a garage near gas, rags, and vehicles is a fire hazard, you just have to be safe.
/ Winter Starting Question #10
Hey Dave,
I've had good luck puting a charger on the battery with a 3 amp slow charge. I think it's enough to warm up the battery a bit.
I have also aimed a torpedo heater at a stubborn Cub and after 5 or 10 minutes, it started right up.
I like the dipstick heater idea, I've never tried that one.
Curt
To be honest I'm not really worried about the tractor turning over and starting, just like the idea of putting less stress on rotating parts by having warm oil right at startup. I know it seems silly since we jump in our cars and start them at 5 below without block heaters, just for me it feels different starting a cold tractor, like I'm abusing it.
I'm probably wrong as usual!
/ Winter Starting Question #12
I used to use a dipstick heater on my Ford 1100 Diesel. It worked pretty good but that black oil was a mess. I now use a block heater that warms it up real good and I don't have to use the glow plugsto start it. Without it the diesel is very hard to start in cold weather. I tried the dipstick heater on a Ford 8-N and it was too long and shorted out and burnt it in two and part fell in the oil pan. Not a good idea.
CC-1863 Ford-1100 Ford 8-N John Deere- 345
Sounds like I ought to avoid a dipstick heater after all. Lefty, thanks for telling your experiences with one.
This morning we got 4" of wet, slushy snow followed by rain, a real mess. It seems so warm to be in the mid 30's and 40's all of a sudden, if it got cold now we'd be encased in ice.
/ Winter Starting Question #14
You might look at a magnetic heater that attaches to your oil pan or wherever it is convenient to attach. When I was looking for something a couple of years ago some of the dealers in this area had them.
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
QA 72" Grapple Attachment (A64126)
QA 72" Grapple...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2005 Amadas 2100 (A64126)
2005 Amadas 2100...
