Winter Project
/ Winter Project #1
Trackks9
green bay, wi.
pt 418/ IHI mini excavator
Been busy rebuilding a older small backhoe I had sitting in the corner of my shed.Having gone though the backhoe I decided to adopt it to use with the P.T. Except for painting, its pretty much done. Everything seems to work, Waiting for the frost to come out of the ground. Spring is slow in coming this year.
/ Winter Project #2
First, welcome to TBN! /forums/images/graemlins/smile.gif
I saw your other post about not getting the photo attached to this post. You do not need to start a whole new thread to make a comment about another post. Just hit reply to the original post, which means that you're replying to yourself. By doing it this way, it keeps everything related to the original post in the same thread, which is less confusing.
Looking forward to seeing your pics in this thread . /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
BTW - I'll delete the other post. /forums/images/graemlins/smile.gif
/ Winter Project
Thank you for the info. on my thread, I am still on a learning curve in reguards to this forum, Retiring at 55, is what I did .That was 7 very fast years ago, One would think my golf would have picked up, It didnt.
/ Winter Project
A follow-up on my winter project thread. This photo shows the attachment plate and how it's hooked to the backhoe.
/ Winter Project
This view shows the backhoe prior to painting.
/ Winter Project #6
Nice job. How much does the backhoe weigh.
I am building a backhoe from a kit from cdp-backhoe, almost have it finished.
/ Winter Project #7
Yes looks like a very nice and extensive job. How much does the hole thing weigh and how well does the PT pick it up and move it around?
/ Winter Project
The PT picks it up okay, It should be curled up to bring the weight close to the machine, J
/ Winter Project #10
I noticed from your bio, that you have a Magnatrac. I have an older model Magnatrac, MT-1800 , transaxle, 16 hp .
I don't use it much since I bought the PT.
/ Winter Project #11
Which hydraulic circuit did you use for the backhoe?
/ Winter Project
JJ
I use the main hyd circuit, and engage the pto when I want to use the hoe. I dug with it for the first time today, I was pleased with its performance, I have several Magna-Tracs including a MT 1800 With a 6 way dozer, witch I use quite a bit. Want to sell your MT-1800? Jim
/ Winter Project #13
Yes, I was planning on selling it, after I got my Pt-1445 all fixed up. It has a scoop and dozer blade. The shipping would be rather steep.
/ Winter Project
Send a picture or two, along with some numbers,of your magna-trac to Trackks9@aol.com How far along are you on your backhoe project? Jim
/ Winter Project #15
On the backhoe, every thing is welded together. A couple of cylinders are on. I need to figure out if I am going to use a joy stick or electric valves. I have three different buckets for it included a fold up grapple leg. I have also built a separate two piece grapple to replace the buckets. See attachments.
/ Winter Project #16
This is what the backhoe should look when I finish.
/ Winter Project
The grapple looks like it would be a very useful attachment,The hoe your building, looks well designed, will make a handy attachment. Have had a number of fellow PT owners pay my project a visit, Leads me to believe that there will be more of these popping up. Jim
/ Winter Project #18
Bumping this thread for reference for another member. It has some pictures of a backhoe adapted to a PT.
1988 BOMAG BW-213PDH-2 SHEEP FOOT ROLLER (A67714)
1988 BOMAG...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2012 KENWORTH T800 TRI-AXLE (A67714)
2012 KENWORTH T800...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2019 Ford F-450 Knapheide Crew Cab Service Truck (A66736)
2019 Ford F-450...
