Winter oil Viscosity
/ Winter oil Viscosity #21
I was using Rotella , but not I got Amsoil only a half of a mile drive from my house. Can't beat that.
/ Winter oil Viscosity #22
I used 10w-40 in my Kubota and John Deere. summer and winter, never any problems in the Michigan winters.
It gets colder than **** here.
/ Winter oil Viscosity #23
I run Rotella T6 synthetic 5w-40 year round
Same here. For the money I don't think you can find better. There is better but not for this money!
Also, make sure the glow plugs are in good working order and that he is using them right. This is often the cause of a hard start over oil viscosity IMO.
/ Winter oil Viscosity #24
Coby
No, I was understanding that starting a cold diesel tractor was made easier by moving the steering wheel. Know nothing about "faster warming"..
I've tried it, and it "seems" to help but then my Deere 4300 has always fired right up with no hesitation since new 18 years ago.
I have no idea how this could possibly help start a tractor. Maybe I am missing something though... anyone have a good reasonable explaination why this would work. I have heard of turning headlights on for a few seconds before starting a car to get the current flowing out of the battery.
Perhaps if power steering is using electric it is doing the same thing.
/ Winter oil Viscosity #25
Check out post #7 in this old thread. http://www.tractorbynet.com/forums/john-deere-owning-operating/192182-easier-winter-starting.html
I think jd110 gave us the answer 6 years ago when he said;
The reason this actually works is due to the closed center hydraulic system. As soon as the engine starts cranking, The hydraulic pump attempts to build 2300 psi. When the oil is warm and relatively thin, the load on the starter is not that great. When the oil is cold it is a different story. Turning the steering wheel opens the circuit to steering motor and bleeds off some of the pressure, causing engine to crank faster.
/ Winter oil Viscosity #26
Anything will help. Just have your starting aids in working condition.
Oil viscosity plays a role in starting ability. Specially in northern winter. It's ok when you can plan your work and plug in the block heater in accordingly. But what if you get the call (emergency) and you need the tractor NOW.
A lighter 0W-40 outperforms a 15W-40 in such a situation.
To the Rotella, in the trucking industry, is known to be consumed by the engine. No matter, wether T4 or T5. I can't comment on the T6.
If you see a difference in the consumption, it's usual.
I use a 0W-40 all year long in truck and tractor, running from the cold canadian winter into the heat of Florida in the summer.
/ Winter oil Viscosity #27
vince, I'm OK with T6. I'll buy whichever oil is cheaper: they're both good oils for what I need. Oil consumption was just a minor footnote: I record when I put oil in my cars between oil changes (10k mile intervals), writing down mileage of course; one day I'll look to parse my data and see if there really is any difference (just for now it's been kind of my observation).
Anyone running turbo-charged engines are going to have some oil loss/consumption. It's the nature of turbos. And, diesels, also the nature of the beasts (cold engines). As I mention, I'm running turbo diesel VWs and my oil change intervals are 10k miles (I could go farther; lab tests tell me that), so it's guaranteed that I'll use oil.
Ran our VW TDI for 7 years and 76.5k miles. Never used a drop of oil, with 10k oil changes.
/ Winter oil Viscosity #28
I use either 5w40 or 5w30 diesel oils. Would use 0w40, but it's hard to find. In my opinion 15w40 is too heavy unless you're always operating between the tropic lines or the equator.
Best source of 5w30 is the Castrol stuff for TDIs at your local VW dealer. Ours doesn't gouge in price. I got a bunch of it with VW cash they were giving away to us.
/ Winter oil Viscosity #29
I run 0-40 if it needs to cold start. My tractor runs 15-40 because it sits in my heated shop always and the 15-40 is what I have a bunch of.
I'd run 0-40 for sure if you needed to start in the cold temps. Its the same oil, just flows better cold which is what you want anyway.
/ Winter oil Viscosity #30
X2, It is recommended for diesel and gasoline engines. I run it in everything I own, boat, motorcycle, lawnmowers, cars, truck and of course tractors. It keeps me from having to keep several oil varieties and weights around.
/ Winter oil Viscosity #31
I've always been under the assumption that Diesel oils don't have "friction modifiers" in them to make the oil more slippery like a full synthetic car oil does. Diesels need this, but car engines benefit from the friction modifiers in them by reducing the friction.
I run car oil in my cars because of this.
/ Winter oil Viscosity #32
The temperature that the "0w" is determined from is -35 to -40 C (@ -40 C=F). If the other end of the determination is "w40", then at ANY temperature between -40 and 212 F that the "w40" is determined will have a HIGHER viscosity than if the oil is a "w30". If the lowest value is a "15w", then it'll have a really higher temperature, at the normal -10 to 40 F starting temperatures of our tractors in the winter. It'll then take probably several seconds more for a 0w40 or certainly a 15w40 oil to reach your valve train than it would if the oil is a 5w30 or 0w30.
Most engine wear occurs at startup. You're slowly destroying your engine by using a 15w40 oil.
/ Winter oil Viscosity #33
Doubt this. The car I was referring to was a turbo diesel.
/ Winter oil Viscosity #34
My new to me son n law has a 4240 and always has 15-40 wt oil in his tractor during the winter. We get temps down in the teens and minus degs in the part of the country where we live. It seems every year he has issues with the tractor starting during the lower temps. I have been helping him with this issue and I have convinced him to keep a Battery tender on the bats and that has helped.
My question is would 10-30 wt make a improvement with his situation and what about a 5- 40 synthetic as well and he could run the 5-40 all summer also and not half to change oil every season. I stopped using 15-40 in my 7.3 Ford PS and opted to use 10-30 and experienced good results and according to what I read the 15-40 shears down to a 30 wt anyway after some time in the engine.
I'm curious what others are doing in this situation,,,,,and before I forget to add the Bats. and voltage output are good and up to date.
Oil weight is a contributing factor in engine wear, not in starting issues. Several things you can do to help the tractor start like it is 60 degrees.
1. Block heater- warms the block so there is less heat loss to the block during starting, equals faster combustion.
2. battery blanket/warmer - keeps the power level up. An 80 watt blanket does wonders.
3. engine oil heater - warm oil is easier flowing and gets to lubricating faster. I use a 150W adhesive heating pad on bottom of the oil pan.
As far as oil, as others have stated, 5W-40 T6 full syn is what I have chosen to run year-round.
/ Winter oil Viscosity #35
Actually, oils DO have an effect on starting in cold conditions. That's the entire point of the 5w and 0w oils. I was reminded of this when starting my log splitter that had been sitting (we've been hitting near teens of late); not until I'd yanked on the starter nearly 3 dozen times (rapidly, because I KNEW the oil was thicker than snot- I couldn't get the necessary cranking speed for the longest time) did the thing start to feel like I wasn't trying to mix cement! If I'd been running a 5w or such in the thing (I believe that it's factory 30w) I'm pretty sure my arm wouldn't pissed off at me! :laughing:
T6 is a good all-around oil. I am currently running Delo 5w-40 and, though I cannot substantiate it (yet), it seems to be doing better than the T6 vis a vis oil consumption (in my ALH TDI VWs; I am also running this oil in my old tractor [new one hasn't had its first oil change yet- it'll be with Delo as well] and in my generator; my old IDI Ford truck may see it, still trying to decide whether it's worth it given it sees so few miles).
First priority in cold weather starting (assuming one has switched to #1) is to make sure your GP system is functioning properly. That should handle well into the teens with little issue.
/ Winter oil Viscosity #36
Actually, oils DO have an effect on starting in cold conditions. That's the entire point of the 5w and 0w oils. I was reminded of this when starting my log splitter that had been sitting (we've been hitting near teens of late); not until I'd yanked on the starter nearly 3 dozen times (rapidly, because I KNEW.....
My apologies, I should have clarified and stated in the instance of an electrical motor (starter) turning an internal combustion engine that oil viscosity is not a major percentage of the necessary power required to turn over the crank shaft. A 'negligible amount' would be the proper term. In your example, the amount of power available from your power source (human body) the increased viscosity may, of course, not be considered "negligible".
/ Winter oil Viscosity #38
I once saw a video made by our research guys. They put a Chrysler (or Dodge?) with 2.2 liter 4 cylinder engine and transparent valve cover in a -40 F/C (they're same at this temp) cold room. They started the engine and filmed it with various oils in it.
With anything BUT 0wxx oil, the valve cover showed a huge amount of oil smoke upon startup because the valve train would get no lubrication for quite a few seconds. On plain Jane oils, the oil smoke was huge.
You get the most engine wear on startup. Get the lowest 1st number in that xxwyy multi grade that you can get that's diesel rated. Or, if you change your oil without many hours on it once/year, you could get by with a gasoline engine oil that would have a 0wxx rating because the main difference between gasoline and diesel oils is additives in the diesel oil to keep the soot in suspension (change on time and not hours, not much soot to worry about suspending).
However, you should be able to get at least a 5w30 diesel oil somewhere, possibly the Castrol at a VW dealership for TDI (turbo diesel) engines. VW has never had an engine failure due to lubrication issues on their diesels, changed generally at 10k miles.
/ Winter oil Viscosity #39
Ralph, yup, lowest lower number is best (how low someone is willing to pay for is up to the individual- find the best value point).
All my ALHs (VE engines) are currently running Delo 5W-40 (subject to switching to Rotella T6 if there's a good price on it). I'm changing at 10k intervals, though according to lab test results I should be able to get several thousand more miles out of my oil: someone went 20k miles and the lab report showed that it was just a little bit beyond service life- 15k would have been OK. Being able to do top-side oil changes makes oil and oil filter changes pretty painless, so 10k is what I'm OK with. VW PD engines require their own spec of oil; from my understanding it's mostly about their cams (stated to be "soft"- more lobes for pushing injectors just adds up to extra stress points).
Deer Target (A64912)
213089 (A64276)
213089 (A64276)
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
John Deere CX15 (A64911)
John Deere CX15...
BX23 TLB 10k OBO
BX23 TLB 10k OBO
2016 Freightliner (A64911)
2016 Freightliner...
