Winter oil Viscosity
/ Winter oil Viscosity #1
Racer11
Member
Mc Louth, Kansas
Kubota 2400 jd 4240
My new to me son n law has a 4240 and always has 15-40 wt oil in his tractor during the winter. We get temps down in the teens and minus degs in the part of the country where we live. It seems every year he has issues with the tractor starting during the lower temps. I have been helping him with this issue and I have convinced him to keep a Battery tender on the bats and that has helped.
My question is would 10-30 wt make a improvement with his situation and what about a 5- 40 synthetic as well and he could run the 5-40 all summer also and not half to change oil every season. I stopped using 15-40 in my 7.3 Ford PS and opted to use 10-30 and experienced good results and according to what I read the 15-40 shears down to a 30 wt anyway after some time in the engine.
I'm curious what others are doing in this situation,,,,,and before I forget to add the Bats. and voltage output are good and up to date.
/ Winter oil Viscosity #2
Is a block heater possible? I had 15/40 in Wisconsin and just plugged it in an hour before go time.
Once it hits zero anything will be a difficult start even with thinner oil, but thinner oil will help. Just make sure it is rated for diesels. I would try the 5w40 synthetic.
/ Winter oil Viscosity #3
I use 15/40 year round. I keep a battery tender on the battery year round. I've never had the tractor not start - even in our coldest weather (-20F). I'm certain that a "thinner" oil and some type of engine coolant heater would help you in cold wx.
/ Winter oil Viscosity #4
I've read here on TBN that while starting, turning a bit on the steering wheel will help. I'd go with thinner oil too, as long as it doesn't cause a problem keeping the oil level up.
/ Winter oil Viscosity #5
Honestly, the 5W-40 full synthetic outperforms in both winter and summer. It's the year 'round oil of choice. Much easier starting due to improved low temperature flow rates. The price difference at Walmart is insignificant.
Typical WalMart stores carry in Rotella, Delo, Mobil, and other top brands for less than $20 a gallon. Why wouldn't you use them?
Not much beats a block heater and a good battery, but using the 5w-40 Full Synethic is a no brainer for us here. Excellent year 'round performance.
/ Winter oil Viscosity #6
From my Kubota OE manual: 10W-30 is an option for all temps, but other weight are listed as possibles. See OE manual
On the Troubleshooting page several possibilities are listed as to "Engine is difficult to start or won't start"
1. No or poor fuel flow............replace the fuel filter
2. Air or water in the fuel system.......a. Check fuel line coupler bolt and nut are tight
b. Bleed the fuel system
c. Remove water from the system and replace the fuel filter
3. Winter oil viscosity...................... a. See above comment about oil selection
b. Use engine block heater if necessary
4. Battery...................................... a battery cables and terminals need good connection
b. remove the battery, store indoors and install when ready to use
Cheers,
Mike
Well, the format layout that I entered didn't turn out in the final.....but it is readable.
/ Winter oil Viscosity #7
Yup, Mobil 1 5-40 in my tractor year round and I use a block heater..
/ Winter oil Viscosity #9
I might be wrong, but I think you're referring to how to warm the hydraulic oil once the tractor is started? -So that 3 PTH and hydraulics (FEL,etc..) are more responsive
My understanding is that cranking the steering wheel to max. will rapidly warm the hydraulic oil as it passes through the relief valve.
/ Winter oil Viscosity #11
John Deere sells a 0w-40 synthetic oil that they say can be left in the engine up to 500 hours between changes if you use their filter. I do this all the time and run 0w-40 year round in all my engines.
/ Winter oil Viscosity #12
Coby
No, I was understanding that starting a cold diesel tractor was made easier by moving the steering wheel. Know nothing about "faster warming"..
I've tried it, and it "seems" to help but then my Deere 4300 has always fired right up with no hesitation since new 18 years ago.
/ Winter oil Viscosity #13
I run Rotella T6 synthetic 5w-40 year round
That's what I use. Buy it when they are having a rebate if you can and save it for when you need it. That stuffs not cheap even at wallyworld.
/ Winter oil Viscosity #14
T6 "not cheap?" If they have Delo 400 5w-40 then go with that. I'm currently running Delo in most everything I have and feel that it's a little better than T6: oil consumption seems lower, though I have no real metrics to go by.
0w-40 is always best (especially for folks in really cold locations) if you can get it for a good price: I know that 5w-40 is readily attainable at decent prices all the time, so I'm not willing to be switching between 5w-40 and 0w-40.
/ Winter oil Viscosity #15
I have Rotella T6 in my tractor, zero turn, push mowers, generators, water pumps, Etc.
As far as consumption I never use any oil between changes in any of them.
/ Winter oil Viscosity #16
vince, I'm OK with T6. I'll buy whichever oil is cheaper: they're both good oils for what I need. Oil consumption was just a minor footnote: I record when I put oil in my cars between oil changes (10k mile intervals), writing down mileage of course; one day I'll look to parse my data and see if there really is any difference (just for now it's been kind of my observation).
Anyone running turbo-charged engines are going to have some oil loss/consumption. It's the nature of turbos. And, diesels, also the nature of the beasts (cold engines). As I mention, I'm running turbo diesel VWs and my oil change intervals are 10k miles (I could go farther; lab tests tell me that), so it's guaranteed that I'll use oil.
/ Winter oil Viscosity #17
My manual calls for 10W30 and I use just that year round. I have a block heater for temps less than 30F. It will start without one, but the heater removes all of the strain of turning over and catching. I change the oil usually 2x/year. I am late this year- but if I wait till spring that will be ok. I change the hydraulic filter once a year as well. - Winters are not what they used to be- Unless I need to, I'd rather not be out there clearing snow at 0F.
/ Winter oil Viscosity #18
Your tractor is a 2003? That's info from 13 years ago. Oils have changed since then. CJ-4 spec supersedes what those specs called for. Go with the 5w-40, it's better for your engine (0w-40 is even better, though the cost differential may be hard to justify). NOTE: my 2000 VW TDIs didn't call for 5w-40 either (and now days that's pretty much what everyone with these cars runs- it's not just something that I'm making up).
/ Winter oil Viscosity #19
Beenthere is correct, spinning the wheel full left to full right as fast as you can, while turning the key until it starts, will help it spin over noticeably faster. It worked on my 1969 JD 3020. I can't tell you why, but I think it has something to do with the type of hydraulic pump the tractor has. I can't say if it will work on the OP's 4240 or not, it may be to "new" of a tractor.
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
CAT 621B Transmission (A68134)
CAT 621B...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
