cmyoung2
Platinum Member
- Joined
- Jun 21, 2010
- Messages
- 552
- Location
- North west NC mountains
- Tractor
- BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Had a break last weekend, decided to catch up on some maintenance on my BCS850. Brakes were a little stiff, as in almost frozen up, so took off wheels, drums, shoes and backing plate. Had to grind the weld and remove the lever, cleaned up the shaft and hole, regreased and rewelded. Then used a cable lube tool, MotionPro I think, to lube all the cables. It is amazing the difference it makes. Brakes that really work and levers that are easy and smooth. The gradual decline is almost not noticed, but man, what a change when you fix it. Has anyone figured a way to grease the brake shaft on these things? Started to drill and tap to put a zerk, but couldn't figure out where to put it so I could actually get a grease gun on it.
