Winter enclosure
/ Winter enclosure #1
Anonymous Poster
Epic Contributor
Hi everyone - happy snow plowing - we got nine yesterday
and they say another storm for monday - had my first chance to plow with the 1845 - it has a rubber lip unlike my 60" on the 425 - I thought it did a great job and I liked having the rubber lip - I have heard some complaints on the sight RE snowplowing - I don't know maybe I am inexperienced but I think they both do a great job and plow right through anything
at least on aspalt - well anyway - I wondering if anyone ever thought about a winter enclosure - would be a fun project - plus I got soaked out there plowing in the middle of the storm.
The only other articulator I know is the Steiner and they offer a cab system - must be unique to deal with the articulation
Any ideas???
/ Winter enclosure #2
there is a convertible car roof and upholstery guy here in plumsteadville, pa that will make me an enclosure for around $300.00. i see his finished work all the time. one of my former partners restores 1-3 mustangs a year and has him do the tops ...very nice work.
pt's cab, i hear, is in the range of $500.00 to 800.00 when i checked last.
if you are interested, he can take the measurements from my 425. let me know.
/ Winter enclosure
Hey Hans - you mentioned "PTs cab - around $800" - I didn't think they made a cab - do they?
Oh - I would need it for the 1845 - the 425 is going to my brother in law - would be cool to have a heater too
and ideas on that?
Oh I noticed that the lights are much brighter on the 1845 - must be the alternator - in any event - I still want to add lights up under the canopy . I recall someone did that recently in a thread - but I think they wired it separate - was wondering why you could not just splice into the existing lights?
I found a set in Northern that are brighter rectangular halogens -
I want to add it to both units - mine and the 425 before my brother in law takes it - also is the alternator the reason for the brightness on the 1845 vs 425 - Does anyone know??
/ Winter enclosure #4
I think our version of the Kohler has a 15 amp alternator. There is a 20 amp available. A couple big halogen headlights in addition to the existing 35 watt headlights could do a number on the battery. I think, and correct me if I'm wrong please;
The two existing headlights are 35 watts each. They could draw about 5.8 amp. Lets just say 5 amps.
Subtract that from the 15 amp alternator and you have 10 amps left to play with(not counting anything else that might draw power, like spark plugs and hydraulic solenoids)
12 watts @ 12 volts = 1 amp
120 watts @ 12 volts = 10 amps
180 watts @ 12 volts = 15 amps
So, two 55 watt halogen headlights could draw about 9 amps.
Does this sound correct?
/ Winter enclosure #5
Mr. M.R. you are absolutely correct, ergo only when moving on the road for short trips do i light the x-mas tree. /forums/images/graemlins/grin.gif
/ Winter enclosure #6
Good. Cause I bought 2 headlights last year to mount under the ROPS and never got around to it. They are the 35 watters, like the standard headlights, so I should be fine.
/ Winter enclosure #7
Chris Asbury the former sales boss at pt, told me that someone installed an RV Air/Heather on top of an 1800 machine. on the 400 series Carhard and enclosure or just Carhard will do fine. /forums/images/graemlins/smile.gif
P.S. Call Don (specifically) and ask him if the guy still makes skirts and enclosures for pt's
/ Winter enclosure #8
I saw a picture of the PT400 series with a hard cab somewhere. Does anyone have a link?
/ Winter enclosure #9
they removed it after the first revision of the attachment pictures. i spoke to don and Eddie (not available on the phone) while i was in Tazwell last week. they told me about someone around there making skirts for pts so you don't have all that dirt and debris on the dust ledger up front ... i will pursue the lead on the phone on Monday and get back to you all
/ Winter enclosure
You think I can splice right into the existing lights?
/ Winter enclosure #11
That's what Power Trac suggested I do with my PT425... However, why should I take their suggestion /forums/images/graemlins/tongue.gif. I'm gonna use a seperated circuit for the extra lights, so I can have them up high, down low or all at once. It'll be so bright I'll have to wear shades /forums/images/graemlins/cool.gif
/ Winter enclosure
hey Moss - where do you wire it in - direct to battery?
or I guess you could trace back and pick up hot somewhere in the wiring - just have not looked at it yet
/ Winter enclosure #13
If you want all the lights on one switch, Power Trac told me to splice in right by one of the headlights or at the switch.
If you want them on a seperate switch, there are some options as to where to pull the power from. There are some leads on the Kohler that provide 12v. I might use a switch/relay combo to keep some of the load off of the switch. Or I might not. Haven't decided yet.
/ Winter enclosure #14
MR, did you ever find the link? I'm also trying to find some info on summer skirt type enclosures.
/ Winter enclosure #15
No. /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif
I know I saw it somewhere but I can't remember if it was in print or on the internet. I've searched all my brochures/documentation and even watched the video they sent me again, but cannot find it anywhere.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2020 FREIGHTLINER CSCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 FREIGHTLINER...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
HARDEE 1084 - 7' ROTARY MOWER (A64278)
HARDEE 1084 - 7'...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
