Winter Cab for 180
/ Winter Cab for 180
Inside view of cab with heater.
Inside door and seat.
Side view of whole tractor
Rear view. My 6' son is standing next to it to show the height of the cab.
Showing rear marker lights and flashing light on top. Light dome has 2 bulbs that alternate. $20 at the local hardware store.
Rear view of brush guard and rear work light.
/ Winter Cab for 180 #27
Nice job. Will you leave the cab on year round and how did the pt work pushing snow?
I haven't decided yet if I will leave the cab on. It will easily come off by removing 4 bolts, disconnect 12v terminals, and slide up over the ROPS. Originally, I had the plow mounted to the quick attach plate but it was 4' in front of the tractor. Trying to plow snow was like moving a barge with a row boat. So now the blade is attached directly to the PT frame and the lift arms allow 5" of vertical travel in the float pos. in case I hit something. Now it works great pushing snow/dirt.
/ Winter Cab for 180 #29
I love the cab work. Awesome job. The only question I have is it seems like quite a bit of work to use that JD plow instead the PowerTrac hydaulic snow blade. Wouldn't the PT blade with tilt that connects to the quick attach be more versatile and still let you pop on the buckets if needed?
OnTheWeb
/ Winter Cab for 180 #30
WOW - that cab is first class, great job.
You must be very handy to be able to build that cab from scratch. Keep the projects coming and photo's of each.
PJ
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2014 Freightliner Bucket Truck (A61307)
2014 Freightliner...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
