Windshield washer fluid reservoir cap
/ Windshield washer fluid reservoir cap #1
homedad
central/ se michigan
Kubota L3130DT
Does anyone have a source for a cheaper cap for a kioti windshield washer fluid reservoir cap. Mine didn’t fit when I bought the tractor and now it’s completely missing. The only one on line was around $18 for something that shouldn’t be more than $5.
/ Windshield washer fluid reservoir cap #2
I have yet to find the right size replacement. So far I purchased a cheap one from Amazon, but it can fall off. It is a bit too big.
/ Windshield washer fluid reservoir cap #3
I've lost several of the darn reservoir caps on tractors as well as my vehicles. I swear there's a gnome around that likes to swipe them.
Quite by accident I found these vinyl caps are a good fit and work as an acceptable replacement:
RVC.
They are very flexible and can be cut to any length. Just put a pinhole in the top for a vent.
They're $3 apiece in lots of 10 but you can get a free sample if you ask. Make sure you order the right diameter.
RVC.
Perfect. That'll work. Thanks.
RVC.
Do you happen to know the exact diameter of the opening? I have some caps that look similar but that tractor is 3 hours away. Thanks.
/ Windshield washer fluid reservoir cap #6
I know - $18 is total crap. But, perhaps, cheaper than a round trip to get a measurement for a cheaper one.
/ Windshield washer fluid reservoir cap #7
I don't have a Kioti but all the reservoir openings on the ones I have are 1.5". It may not be standard though. Maybe someone with a Kioti can post a measurement.
I'm hoping.
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
Ford 8600 (A64127)
Ford 8600 (A64127)
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
