windrow compost turner
/ windrow compost turner #1
MikeF
Maryland
JD 3039R cab
looking to see if anyone has built a pull type windrow compost turner. I am considering the build so I thought I would look here to see if anyone else has made one.
thanks
Mike
/ windrow compost turner #2
Have a look at what the mushroom farms use, might give you some ideas .
/ windrow compost turner #3
Take the beaters off a manure spreader and pull that through your windrow. ;)
/ windrow compost turner #4
U-tube showed a Cat that had a "conveyor" attached to the front blade type thing... The conveyor rotated around the blade in a continuous loop moving soil that had been removed from a ditch... the pipe laid.... the conveyor covered the pipe and filled in the ditch...
Looked as if it would work very well for a complete turn of the windrow...
Weld angle iron to either type link... add adjusters and rollers.. Basically it's a manure spreader mounted on it's side....
U-TUBE VIDEO OF THE CAT
Introduction to the Viking Power Dozer - YouTube
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
(1) UNUSED 12" RUBBER TRACK (A64280)
(1) UNUSED 12"...
48in Forks and Frame Skid Steer Attachment (A61572)
48in Forks and...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
Kubota Pull-Behind Spreader Tractor Attachment (A61572)
Kubota Pull-Behind...
Caterpillar D6C Dozer Parts and Service Manuals (A63117)
Caterpillar D6C...
