windrow compost turner
/ windrow compost turner #1
MikeF
Maryland
JD 3039R cab
looking to see if anyone has built a pull type windrow compost turner. I am considering the build so I thought I would look here to see if anyone else has made one.
thanks
Mike
/ windrow compost turner #2
Have a look at what the mushroom farms use, might give you some ideas .
/ windrow compost turner #3
Take the beaters off a manure spreader and pull that through your windrow. ;)
/ windrow compost turner #4
U-tube showed a Cat that had a "conveyor" attached to the front blade type thing... The conveyor rotated around the blade in a continuous loop moving soil that had been removed from a ditch... the pipe laid.... the conveyor covered the pipe and filled in the ditch...
Looked as if it would work very well for a complete turn of the windrow...
Weld angle iron to either type link... add adjusters and rollers.. Basically it's a manure spreader mounted on it's side....
U-TUBE VIDEO OF THE CAT
Introduction to the Viking Power Dozer - YouTube
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
