Eddie,
You never cease to absolutely amaze me. I had no problem at all with his carpentry skills. The frame work is fine, as you say. This guy is actually a very skilled framer. There are extra studs in the first floor walls as they have some load bearing. With the 2' cantilever in the front (porch is the front) I wanted to take weight off of the front and distribute to the middle. The architect agreed, so it was designed to have load bearing walls in the middle of the house. The stairs are temporary, for construction only.
The commercial building I rent in is owned by a very large window/glass contractor from out of state. He told me to use low expanding foam around the windows. The Andersen instructions also say that, so I thought it was a good idea. My heating contractor told me to caulk the seams of the OSB and anywhere else air may come into the frame.
The unfinished frame on the back wall is a continuation of the 12-12 pitch roof to the left side when you look at the pic of the rear of the house. This is another of those things that he didn't finish.
I already placed joist hangers on the joists going to the blind header. I should take pics of the ones he put in crooked before I repair them. Another contractor told me that he was working oin a job with this guy. When the contractor brought a box of joist hangers and hurricane straps to the site, this guy told him to "take those things back, I don't use them."
Eddie, I hope you get discovered. You should do a tv show. You can look at a picture over the internet and give the history and ability of the person that did the work. You also know what to do, what not to do, and how to correct the damage done. Your talents are many and I truly appreciate your help. I also appreciate everyone elses help, please don't feel left out and not appreciated. Curlydave, Charles, Dan, tommyu, thanks everybody for all your help.
Oh, when he met me at the house, he asked me what was wrong. I asked him if there was anything wrong with the way the windows were installed. He asked what was wrong with them. I went thru the procedure for installing windows. He looked at me like a deer in the headlights and said, "Maybe I should retire." I told him, "Maybe you should." Believe it or not, I actually felt bad for the guy. He isn't a bad person, I just think he needs to research what he doesn't know. Nobody knows everything, the secret is to find the info you need to do it right and not be too proud to admit that you don't know everything. Through all this, if he swallowed his pride and came back with every intent of making things right, I would still be his friend and let him continue.
Thanks again, Andy.
