Winches
   / Winches #22
I have been tryin to buy the top link for my Cub Cadet yea I know its just a small tractor but, looking for that top link to raise a plow is hard to find. Finally found one for sale and the fellow wanted 200 dollars for it. So I thought what if I bolted a 1/4" steel plate to where it mounts and put a cheap 12 volt winch on there. Man you talk about easy lifting of the plow when you get to the end of a row. When i had a top link I had to stop the tractor put it in reverse and back up at least a inch so I could find enough strength in my arm to lift the handle that lifted the plow.
Now when I get to the end of the row while plowing I hit the switch and the plow is up and I can make my turn and drop it going the other way and when I am done I dont have the pain in my arms after all that lifting.
Calvin
20(10) UNUSED SDLANCH 2.5CM X 3.5M RATCHET STRAPS (A58375)
20(10) UNUSED...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
Riding Mower (A59231)
M998 (A55852)
M998 (A55852)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
