winch
/ winch #1
xterra
Michigan
BX2380
Will any winch fit a rtv 900? I bought a 2000lbs one on sale for 50 bucks.
/ winch #2
I'm interested in this myself.
Is there a "right" size winch? Is 2000lbs. enough for general use like cutting wood? Is there an optimum capacity for a utv winch?
/ winch #3
For moving wood or something along those lines the 2k winch is enough....to actually pull the 900 out of mud if it's stuck you'll want a 3.5K + winch...if you use a 2k with a winch block to double your pull you can get by with the 2k winch but it's going to be alot slower.
/ winch #5
From your chart it looks like the mount will fit a lot of winches. The bolt dimensions are listed as are many brand names. If your is different I'm sure it could be made to fit.
/ winch
Cool. I'm kinda new to this. Going to use it for pulling logs out of the woods.
/ winch #7
If you are going to pull logs it won't last long. winching to the unit and then chaining it to a drawbar will save your winch.
If you pull a log up and just take off it will strip the gears right out of your winch. When you have a hangup and the pulling unit continues the energy of the forward moving unit will exceed the rating of the winch.
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
CADMAN 4500 WIDE BODY HARD HOSE REEL (A63291)
CADMAN 4500 WIDE...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
