Winch Modifications
/ Winch Modifications #83
Bob, does any of your valves have PB? Maybe you are going to install the new valve first in line.
Yes, they have power beyond. I think this valve will work here.
/ Winch Modifications #85
BobRip
Sympathize with your winch issues. We looked at the PT winch and decided against it, because couldn't figure out how to spool the cable out without powering, and it takes way too much effort to freespool/turn a geroler motor. So... took a QA plate and welded two parallel two inch towing receivers on it for front end, and then welded (2) two inch receivers on the back of the PT near the bottom back corners that correspond to the identical spacing of front QA receivers, mounted a Mile Marker hyd. winch on a plate with clutches to free spool, and two speeds for less than the cost of the PT winch. It plugs into the towing receivers at either end of the PT or remotely to nylon straps so we made up longer hoses that will let us also hook the winch to a nearby tree for the hard pulls using the steering oil from the forward quick disconnects, but also planning to install two tandem center 12V solenoid valves in the engine compartment to operate the winch and a hyd. gantry boom with a chain hook on the back of the PT to haul/lift logs, or get us unstuck from the back end. Two joysticks at panel run back winch and lift cylinder from oil tapped (in series)in engine comp. before it runs forward to steering.
/ Winch Modifications #86
BobRip
I think we'd all love to see a thread and pictures of that! :) :thumbsup:
/ Winch Modifications #87
Hey Moss, I'm computer illiterate and don't know how to insert pictures but I can e mail you pictures of what I built, I got that part down. FAZ
BobRip
You made the right choice for the right reasons. No manual spool out is a pain, especially when the controls are in the front and the winch is in the back. I just helped a friend install a Mile Maker hyd winch on a jeep and it is nice. It is slow, but it has two speeds (high speed appears to be just for wind and unwind with no torque) and freewheeling. I would swap in a heart beat, but I think my friend would notice.
/ Winch Modifications #90
JJ
Thanks for the picture info. We'll see if my Neanderthal brain can figure out pictures, I'm functionally illiterate.
Mile Marker requests no pressures over 1500 which achieves 7,000 lbs pull. Using Vickers crossover double relief valve (cushion valve) that is adjusts 600 to 3400 psi which mounts to winch frame. If pulling pressure exceeds set pressures it just dumps the oil into the returning oil, and also absorbs the momentary shocks while pulling. Also have a pressure guage T'd into the pulling circuit mounted on dash that lets me know whats going on. This winch far exceeds the holding capacity of the 425, so welding a hook directly behind the winch frame that allow my nylon straps to go back under the tractor around a tree and back to the winch so the stress of pulling tough logs bypasses the tractor frame, and the load is transferred directly to the tree base. I can do this from either front or back of tractor, or just drop the winch frame in front of a convenient tree, nylon strap it to tree, and just feed it oil from my 425 through the 12' long hoses with quick disconects. The cushion valve always stays with the winch frame. It makes it versatile.
Strong like bull :D
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A59231)
2008 Regal 2565...
Flatbed Truck (A55973)
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Autocar...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
